Old 06-24-2015, 05:34 AM   #1
fourbangerbob
Default Timing with a B distributer
What should I set my "Starting" timing at with a "B" centrif advance distributer installed in my Banger A?
At 2000 rpm what should my total advance be? I installed a degree wheel like newer cars have to read the timing.
fourbangerbob is offline   Reply With Quote
Old 06-24-2015, 12:25 PM   #2
62pan
Default Re: Timing with a B distributer
I am using a 6-1 Winfield head and if I remember correctly I set my B dist at 5 degrees advanced. Total advance then is 20 degrees.
62pan is offline   Reply With Quote
Old 06-25-2015, 03:05 AM   #3
colin1928
colin1928's Avatar
Have not done 1 for a while but believe I start at 18 deg static and 32 deg total
colin1928 is offline   Reply With Quote
Old 06-25-2015, 09:13 AM   #4
H. L. Chauvin
For anyone trying to time a centrifugally advanced B Distributor on an A engine, and using the conventional method of timing by inserting the front timing pin in the recess in the timing gear, first:
1. Do you know if your timing cover is a Model A timing cover which was designed for use with a manual advanced A distributor? or,
2. Do you know if your timing cover is a different, Model B timing cover which was designed for use with a centrifugal advanced B distributor?
3. What type of head is on one's A engine?
Once one's timing cover is identified as either an A timing cover or a B timing cover, (e.g., differences are indicated Mr. Vince Falter's "Model A Ford Garage"), one can continue to become informed on how to time one's engine using one's timing pin.
H. L. Chauvin is offline   Reply With Quote
