Old 05-27-2015, 12:55 PM   #1
39topless
Question Prime to start.
I have installed two 97's, that I rebuilt, in a 2 X 2 setup on my stock '39 V8. The only way to get this started is to prime the carbs. I have also installed a new electric fuel pump that is run through a new regulator that was factory set to 2.5. I do start the pump for about 5 seconds before turning the engine over. Do the idle adjustment screws have an effect on the startup? They are set to about 3.5 turns out. What should I try?
Thanks, Phil
39topless is offline   Reply With Quote
Old 05-27-2015, 01:16 PM   #2
adileo
adileo's Avatar
Default Re: Prime to start.
After you prime does it run normal? It's just starting the problem?
adileo is offline   Reply With Quote
Old 05-27-2015, 01:18 PM   #3
54vicky
54vicky's Avatar
accelerator pumps?
54vicky is offline   Reply With Quote
Old 05-27-2015, 02:00 PM   #4
39topless
After prime it runs fine. New accelerator pumps.
Old 05-27-2015, 03:40 PM   #5
scicala
scicala's Avatar
It doesn't make a lot of sense. If it runs good after being primed, and the accel pumps are working, it should start when you pump the throttle to squirt the accel pumps and/or pull out the choke a little bit. Don't know what to tell you.
Sal
scicala is offline   Reply With Quote
Old 05-27-2015, 06:20 PM   #6
54vicky
54vicky's Avatar
have you looked down throat of carbs when pumping throttle?new does not mean that they do the job.new and working are worlds apart these days with parts coming from who knows where easy to check
Old 05-28-2015, 05:09 AM   #7
chap52
chap52's Avatar
First off, as suggested first give a peek to make sure it's getting gas.
Is this just a cold start, or every start? Did you sync the carbs with a uni-sync? (Check past posts for tuning dual carbs)
I believe that you will find the ideal start scenario after a few different combinations are tried. My truck with dual 94's, electric fuel pump has told me that the cold start procedure it likes is, turn on ignition, listen to hear fuel pump running, 3/4 choke, two quick pumps on the gas pedal and engage the starter. VAROOM...
Please keep us posted, we all learn from these adventures.
Old 05-28-2015, 11:00 AM   #8
39topless
Uni-sync? wow, never heard of that. I'll get on it. Thanks so much.
Phil
Old 05-28-2015, 11:36 AM   #9
WestCoast
some times people lose the bb sized check ball at the bottom of the accelerator well, with out that ball in place no fuel will be squirted down the carb throats, 3 1/2 turns out on the idle adjustment screw seems a little to much to me, 1 1/2 to 2 1/2 should be plenty, sounds like you may have a vacuum leak in the fuel system
WestCoast is offline   Reply With Quote
Old 05-28-2015, 12:30 PM   #10
f1builder
yes, a vacuum leak or something might be causing your fuel to bleed back into the line/tank when shut down. check your gas cap too for vent.
f1builder is offline   Reply With Quote
