That is an early 1930. It's possibly a Coupe body built by Briggs. Look on the firewall on the right side where the patent plate should be for a second plate or a pair of holes below the four holes for the Ford plate.
All new reproduction floor pans have been installed. Some parts such as deck lid lower stops are missing. The seat riser is also missing the holes for the two lower spring catches or loops to snap into. Correction, I see the stops at least.
http://www.abarnyard.com/ |
