Old 05-22-2015, 06:55 PM   #1
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: A question on Les Andrews's ring specs
You say you can't feel them with your fingernails. From what I see, if they're IRON rings, this may be "normal" until the ring surfaces polish over & those marks "may" go away.
IF, the marks were from pistons too tight, you should see, almost like ALUJIMUM like deposits in the marks. I'd just drive it & DON'T WURRY! BUT, WHUT DO I KNOW--------------?????????????????????--(The Dorg's SMILIN')
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-22-2015, 08:18 PM   #2
700rpm
700rpm's Avatar
Bill W.
Right, Bill. I am definitely influenced by the attitude my father passed on to me, similar to your philospohy: "It's a Model A Ford. If it runs, drive it." But I'm a little fussier. And it's more expensive to fix problems now than it was in 1955. So... I fuss.
No aluminum deposits observable.
Ray Horton, Portland, OR
Old 05-22-2015, 09:46 PM   #3
BILL WILLIAMSON
Why fuss with it. My opinion, (for whatever it's worth??) IS, if you put an engine together properly, use good parts, have CONFIDENCE in your work, just drive & enjoy it! I've seen folks fuss too much & literally destroy a car by taking it apart, puttin' it together, etc & literally wear out the fasteners & usually end up with a sub-standard performing car.
MAYBE I'll just learn to keep my opinions to MYSELF & get some of my own things done! Sorry if I sound TESTY, you should see me when I get REALLY pissed off & run out of "HUMOR"??
I only post helps that have worked for me, personally, in all my years of auto repair----------BED TIME!
Bill W. & Buster T.
