Old 03-24-2015, 12:49 PM   #1
hardtimes
hardtimes's Avatar
Default Re: burlington crank
Originally Posted by jallison15 View Post
It is not recommended to drill for full pressure, we do not have stroker cranks available.
Thanks for your response !
I think that I understand your 'reasoning' for not recommending drilling, as the use of A size throws , IMO, is somewhat asking for trouble when taking more metal away from them..no ?
Anyway, the broken cranks that I've seen (from another maker) were all drilled and broke thru the drilled rod throws.
Old 03-24-2015, 02:31 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Who was that manufacturer? SCAT is unaware there have been any failures to any of their drilled A crankshafts. While I realize there are / have been other Model-A crankshaft manufacturers, maybe this needs to be clarified to who was, --or was NOT the manufacturer so not to create confusion at a later date.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
