Old 03-12-2015, 11:01 PM   #1
PepeLoco
PepeLoco's Avatar
Default First Oil Change in 50 years
I don't think anyone has linked to this vid before. It's not mine. Interesting.
https://www.youtube.com/watch?v=AhVo7-gzJo4
Enjoy..
Pepe
PepeLoco is offline   Reply With Quote
Old 03-12-2015, 11:32 PM   #2
Pilotdave
Pilotdave's Avatar
Default Re: First Oil Change in 50 years
Nasty looking stuff!
Pilotdave is offline   Reply With Quote
Old 03-13-2015, 01:22 AM   #3
Synchro909
Synchro909's Avatar
I watched this clip some months ago. Oil aint like wine that gets better with age.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-13-2015, 01:35 AM   #4
Tom Endy
Tom Endy's Avatar
I would suggest you remove the valve cover as you will likely find the same kind of sludge inside the valve chamber and in the return tube mounted on the side. This needs to be cleaned out as well. The oil appears to me to have traces of water emulsified in it. I would only run the new oil a hundred miles or less and then change it again. You may flush more sludge out and you can look for traces of water in the oil. if you do find traces of water you might want to consider replacing the head gasket
Tom Endy
Old 03-13-2015, 03:57 AM   #5
C26Pinelake
Tom Endy
A very logical approach. And after the first 50-100 mile change you might want to repeat it . I personally would pull the pan even before I'd put any more miles on it.
Wayne
C26Pinelake is offline   Reply With Quote
Old 03-13-2015, 08:47 AM   #6
mcorrell
mcorrell's Avatar
This makes me concerened about my car. I have no idea when the oil was last changed before I received the car and changed the oil last summer. The oil that was drained gave no indication that it was THAT bad, but I am tempted to pull the pan and valve cover to check it out. There was a quart of oil my dad had purchased back in 2002 behind the seat. The receipt showed the purchase was for the single quart, so I can assume the oil was not changed at that time nor had it been changed until 2014.
1929 (early) Model A Special Coupe - restored to original
1964 Buick Wildcat convertible
mcorrell is offline   Reply With Quote
Old 03-13-2015, 10:26 AM   #7
John Duden
John Duden's Avatar
Dump it in the rear end and use it as80/90!
John Duden is offline   Reply With Quote
Old 03-13-2015, 11:13 AM   #8
burner31
burner31's Avatar
My '31 town sedan sat for over fifty years, the owner before had rebuilt the engine, filled it with oil and maybe ran it once or twice, never leaving the garage. When I got the car in late 2014. I start dismantling the engine when I discover the fresh rebuild, dropping the pan showed still clean oil with little to no sludge, some settling of the oil occurred over those fifty years, but nothing near as bad as I have seen in other cars sitting for that long.
It just goes to show you...you never know what you going to find...in a Model A.
Keith
Shawnee OK
'31 SW 160-B
Old 03-13-2015, 11:21 AM   #9
Rowdy
Anyone considering starting an engine that has been sitting for a long time should see this video. How well do you think those rods oiled with all of that gunk in the dipper tray? Did you remember to clean the gunk from the valve chamber also? Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
