Old 03-12-2015, 10:01 AM   #6
svm99
Default Re: Shifting tower/arm on my '42 PU
I'd say the 1/4" pin which aligns the shifter is worn and is allowing the shifter to "rotate" in the top. Carefully extract the pin, cut the shank from a 1/4" drill and try again. This is a quick fix but may get you back on the road.
I would think the ball tip has less to do with this than the pin does.
Good Luck, Paul J.
svm99 is offline   Reply With Quote
