Old 02-07-2015, 04:01 PM   #1
40ford
40ford's Avatar
Default 40 Oil Pan Leak:
The oil pan on my 40 is dripping pretty bad on the bottom of oil pan at that split key.What is the purpose of this key?Is there anything that can be done on the outside to slow leak?
40ford is offline   Reply With Quote
Old 02-07-2015, 04:22 PM   #2
30-9
Default Re: 40 Oil Pan Leak:
Did u just do an oil change? Sounds like u have too much oil
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 02-07-2015, 04:25 PM   #3
4tford
4tford's Avatar
The key is there to keep the drain hole open. The oil will be coming from a leak at the rear seal. Will need to pull the pan to fix.
4tford is offline   Reply With Quote
Old 02-07-2015, 07:04 PM   #4
johnny
I had the same problem ,oil leaking from the hole under the flywheel .The oil pan has two sections one is under the motor part and holds the oil ,the other is under the fly wheel and is dry .Mine had and quite possible your might have a small rust hole between the two which lets the oil out into the flywheel section. With mine it seemed to be worse when the motor was hot. I dropped the pan welded up the small hole and no more leaks John.
johnny is offline   Reply With Quote
Old 02-08-2015, 09:49 AM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
The 40 Ford 221 engine does not have a rear seal, it has a slinger made on the crank that is supposed to sling the oil back into the pan. There is a cork gasket that seals the back of the pan, it may not on right. if you over fill the oil pan it will leak. Walt
Old 02-08-2015, 10:38 AM   #6
4tford
4tford's Avatar
I was referring to the cork as a seal. Also I use a dab of silicone at the corners of the gasket and where it meets the cork.
Old 02-08-2015, 06:41 PM   #7
Ken/Alabama
Ken/Alabama's Avatar
It will also leak if the rear main bearing has too much wear or clearence.
Old 02-08-2015, 10:33 PM   #8
Jack E/NJ
Jack E/NJ's Avatar
>>>The oil pan on my 40 is dripping pretty bad >>>
Define pretty bad.
Jack E/NJ
Jack E/NJ is online now   Reply With Quote
Old 02-10-2015, 05:38 AM   #9
40ford
40ford's Avatar
25 drops in 1 minute while sitting at idle!
Old 02-10-2015, 06:36 AM   #10
Sixseven
Sixseven's Avatar
That's "pretty bad". It sounds like some good advice in this post already. Have you pulled the pan?
Sixseven is offline   Reply With Quote
Old 02-10-2015, 07:11 AM   #11
40ford
40ford's Avatar
No.Car has been sitting for about 20 years.I was hoping things would get better since it is running again?
Old 02-10-2015, 08:01 AM   #12
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
When my '36 221 Babbit-bearing motor started leaking like that, it turned out the cork gasket mentioned previously, between the two sections of the oil pan, had just disintegrated. No choice but to pull the pan, had the added benefit of clearing a good amount of sludge out of the pan which I didn't really know was there.
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 02-10-2015, 08:25 AM   #13
gmc1941
gmc1941's Avatar
Isn't most of our Fords self oiling, ha ha
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
