Old 01-30-2015, 07:37 PM   #10
JohnLaVoy
JohnLaVoy's Avatar
Default Re: new dist body,s
We reviewed this a few issues ago. The USA made distributor bodies tend to have the quality problem where the issue you described comes up. The off shore one is dead on. You can tell the difference by looking for the notch that is in the body to align it on the distributor, USA has two so you can use it on a B dist. the off shore only has one. The off shore is also bakalite which you can't use in the USA that is why they are making them off shore.
JohnLaVoy is offline   Reply With Quote
