Old 01-20-2015, 11:13 PM   #1
jzebert
Default Rear end noise
I have a 28 roadster pickup. While it is in motion, there is a scraping noise that originates from the rear end. The noise is most noticeable when slowing down or turning. I am hoping that someone might have some suggestions for this issue.
jzebert is offline   Reply With Quote
Old 01-20-2015, 11:44 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Rear end noise
I'll bet the brake drums are starting to rub against the back plates.
Check to see that the axles are tight. The nut should be torqued at least 100ftlbs.
Raise the axle up to get the tire off the ground. Grab the top of the wheel and try to shake it in and out. If it moves at all the hub may be loose on the axle. Mine made noise and both axles were loose and had stripped threads. The only thing keeping my wheels on were the cotter pins. Check this before you drive it again.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 01-20-2015, 11:51 PM   #3
Fullraceflathead
If you find hubs are loose on the axle they make shims that will take up the space and prevent the drums from rubbing the back plates and making noise. They are only a few dollars. I used one on my Roadster Pickup.
I had to file my axles because of the stripped threads and re-thread them to 9/16 - 18 pitch. Original threads are 5/8 - 18 pitch. I made a step by step video showing how I did mine on Youtube (1928 Ford Model A Stripped Axle Repair). Hopefully yours just need to be re torqued. Don't forget to use a NEW Cotter Pin after Torqued.
-Henry Ford
1941 Willy's Pickup
