Old 01-12-2015, 12:12 PM   #1
700rpm
700rpm's Avatar
Default Re: Gas leak near steering column
Originally Posted by bluesman31 View Post
I didn't realize how common an issue this is. Thanks found the links
Does the cowl have to be completely disassembled and removed and repainted on a 28 Phaeton to remove the tank??
On a 28 you can remove the tank relatively easily (vs a 30-31) and must do this to do a proper repair. You might be able to make some sort of patch with the tank in place, but if you want to make it pretty it will have to come out.
Ray Horton, Portland, OR
