Old 01-08-2015, 05:18 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Prussian blue
Use a small brush, such as the small flat acid brush plumbers use, then wipe a thin coating on the gear teeth. Turn the driving gear back and forth so it wipes across the blue and shows a pattern of contact. You want to see the pattern on the drive side of the teeth, and on the coast side of the teeth. Old Motors Manuals have a section showing how to read the patterns.
