12-24-2014, 11:44 AM | #1 |
Manifold & WCFB throttle bore size
I have an Offenhauser 1078 4bbl manifold but it's at the engine builder and I can't measure it. I have read about every thread/post about these manifolds and carb. options but saw no specifications. I have considered another Offenhauser 1078 for another flathead that I have and was curious how the WCFB throttle bore and the 1078 compared. I have a perspective source for early Carters used on early '50s Buicks and Olds.
Happy Holidays, Howard |
12-24-2014, 11:47 AM | #2 |
Re: Manifold & WCFB throttle bore size
Can't help with your question,but if you have too many carbs let me know.
12-24-2014, 11:56 AM | #3 |
Texas Webb, I've contacted the source and haven't heard back yet. I don't know if he's into the "rebuild and sell" business but if he has the cores, and wants the business, I'll let you know.
Howard |
12-24-2014, 12:16 PM | #4 |
A quote from an Offy. 1078 seller.
"The Offy single 4-barrel intake is drilled for the early ’50s small Carter WCFB carb-mounting pattern, so an adapter is mandatory with a Holley carb, even if you don’t have other linkage- or choke-clearance issues."
12-24-2014, 01:28 PM | #5 |
Texas webb, are you looking for a WCFB or an AFB?
12-24-2014, 03:23 PM | #6 |
Ol' Ron |
12-24-2014, 05:00 PM | #7 |
