Old 12-23-2014, 09:58 AM   #9
Gold Digger
Default Re: Tighter Steering, Wobble Remains
Just a tip on setting the toe-in. Never try to set it with the wheels off the floor. If I have done some kind of work on front end and want to set the toe-in I always drive around the block and pull in the shop with out backing up and then set the toe-in. That way all the looseness is in the forward movement direction which is the direction the car will travel most of the time.
Gold Digger is offline   Reply With Quote
