Old 09-01-2013, 12:40 PM   #1
mrtexas
mrtexas's Avatar
Default 29 roadster seat back upholstery
Is the seatback upholstery attached to the wooden rail where the top is attached or wrapped around the springs in front of the wooden rail?
For pictures see my website
http://mrtexascitrus.weebly.com/
mrtexas is offline   Reply With Quote
Old 09-01-2013, 01:13 PM   #2
firetique57
firetique57's Avatar
Default Re: 28 open cab pickup seat back and 29 roadster seat back
u forgot to post pics
firetique57 is offline   Reply With Quote
Old 09-01-2013, 04:27 PM   #3
mrtexas
mrtexas's Avatar
If you are logged in you should see the pictures or look on my website:
Old 09-01-2013, 05:00 PM   #4
Charles Reese
Charles Reese's Avatar
Originally Posted by mrtexas View Post
This is how my new interior came back from the upholstery shop. The cover that was taken off attached to the wooden rail. Is this how the seat back is supposed to be attached? The roadster seat back before installation. Same question for roadster.
Open pickup looks fine ... i have no knowledge for the Roadster. As for details, attaching a photo of original seat (provided to me by Mr. Neil Wilson). However, the 'original' top on the Open Pickup was permanently tacked to the tack board, not removable.
Charles Reese is offline   Reply With Quote
Old 09-01-2013, 06:05 PM   #5
Pickupman
I'm logged in and don't see your Pics?
Pickupman is offline   Reply With Quote
Old 09-01-2013, 09:27 PM   #6
Charles Reese
not sure of problem .. i see it (just 1) .... other folks?
Old 09-01-2013, 10:21 PM   #7
Steve Wastler
Steve Wastler's Avatar
I see Charles' pic, not OP
Steve Wastler is offline   Reply With Quote
Old 09-01-2013, 10:50 PM   #8
Pickupman
I see Charles pic but not Mr. Texas's pic.
Old 09-02-2013, 04:03 PM   #9
mrtexas
mrtexas's Avatar
Default Re: 29 roadster seat back upholstery
Where are the 29 roadster experts out there?
Old 09-02-2013, 05:18 PM   #10
Vern
Vern's Avatar
I'm certainly no expert! The seat back fabric on my '28 roadster is attached to the wood top rail. I don't. Know how the roadster pickup seat
Vern is offline   Reply With Quote
Old 09-02-2013, 05:35 PM   #11
Marco Tahtaras
Marco Tahtaras's Avatar
My Open (and Closed) Cab seats Charles showed are not quite like the Roadster.
I don't have pics handy of a '29 Roadster I've done but the construction is identical to a 35-A Phaeton.
There is a two layer "extra" flap sewn into the cover. The lower layer is just heavy weight muslin.
After the cushion assembly as shown is mounted into the body, the muslin layer is drawn back tacked to the wooden tack rail. A thin layer of padding is placed over the muslin to provid a padded base for the top flap which is then drawn over the rail and tacked just above the steel body.
Now, LB (and probably others) Don't or can't make it quite correctly so they sew the flap so instead of the welting following the corner of the cushion, they have the welting and flap pull straight across the top and over the wooden tack rail.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 09-02-2013, 05:42 PM   #12
wrndln
Yes, the upholstery is wrapped around the wood rail and attached to the back part of the beltrail. Once you install the seatback you can't easily remove it as it is permanently attached. The top for the roadster goes over the seatback I just described. I might have some pictures of how the seatback is attached, but it is a pain to post pictures here. My email is: [email protected].
Rusty Nelson
Old 09-03-2013, 06:19 AM   #13
springerpete
springerpete's Avatar
I can confirm the above with my 29. Seat back upholstery is fastened to the tack rail at the top of the backrest. Seat back can be flipped up but not removed. There are 2 pointed clips that hold the seat back spring in place. They are fastened to the wood frame at the bottom. The spring structure slides ( with difficulty) into them and is held in place. It is also difficult to get the seat back un-clipped from these fittings.
springerpete is offline   Reply With Quote
