Old 03-10-2013, 02:40 AM   #1
kustoms36
kustoms36's Avatar
Default 48 generator with fan mounted???
hi can i use a 48 generator, and modify for fan mounted for my 36??thanks for reply
kustoms36 is offline   Reply With Quote
Old 03-10-2013, 03:36 AM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 48 generator with fan mounted???
You would need to get a pulley from a about 38 to 40 that has the four lugs to take the fan and swap them .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-10-2013, 09:53 AM   #3
Charlie ny
kustoms,
I recently modified an 8BA generator pulley for a customer to mount
the fan to. If you can't find the correct pulley let me know.
Thanks,
Charlie ny
[email protected]
Old 03-10-2013, 01:19 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
I may have a pulley like you need listed here. Check this ad and page down to pictures of pulleys.
https://www.fordbarn.com/forum/showthread.php?t=10508
John
Old 03-11-2013, 10:08 PM   #5
John R
Mac's has repro fan-mount 78-10130 generator pulleys for the large-shaft 37, 38 and 39 std 3-brush generators. A possible problem: this pulley ideally should be used with the compatible 78-10139 front plate, which apparently is not reproduced. I don't know if it will work with other front plates.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 03-11-2013, 10:16 PM   #6
John R
Another thought: Back in the day, aftermarket suppliers produced a fan-mount generator pulley specifically for the 40-48 generators with the screw-on pulleys. Probably a bit scarce, but I did see one of these on the auction site a while ago.
Old 03-11-2013, 10:48 PM   #7
nospartsman
The most compatible generator with pulley fan mount and that functions with voltage regulator is the 1939 Ford Standard and 1939 pickup and truck.
nospartsman is offline   Reply With Quote
Old 03-12-2013, 08:03 AM   #8
G.M.
It's not just a matter of finding a pulley that fits but there are various sizes. You don't want one that it to large or it won't charge right. This is real important if you use an alternator. The ones with the pulley OD close to the threads for the screws are best. G.M.
www.fordcollector.com
Old 02-18-2025, 12:16 PM   #9
big deuce
big deuce's Avatar
I know this is an old thread, but still relevant info. Here is a prime example of an aftermarket pulley I just picked up.
big deuce is offline   Reply With Quote
Old 02-18-2025, 12:22 PM   #10
petehoovie
petehoovie's Avatar
