The Ford Barn
-   -   48 generator with fan mounted??? (https://www.fordbarn.com/forum/showthread.php?t=99974)
kustoms36 03-10-2013 02:40 AM
hi can i use a 48 generator, and modify for fan mounted for my 36??thanks for reply
FlatheadTed 03-10-2013 03:36 AM
Re: 48 generator with fan mounted???
You would need to get a pulley from a about 38 to 40 that has the four lugs to take the fan and swap them .
Charlie ny 03-10-2013 09:53 AM
kustoms,
I recently modified an 8BA generator pulley for a customer to mount
the fan to. If you can't find the correct pulley let me know.
Thanks,
Charlie ny
[email protected]
JM 35 Sedan 03-10-2013 01:19 PM
I may have a pulley like you need listed here. Check this ad and page down to pictures of pulleys.
https://www.fordbarn.com/forum/showthread.php?t=10508
John R 03-11-2013 10:08 PM
Mac's has repro fan-mount 78-10130 generator pulleys for the large-shaft 37, 38 and 39 std 3-brush generators. A possible problem: this pulley ideally should be used with the compatible 78-10139 front plate, which apparently is not reproduced. I don't know if it will work with other front plates.
John R 03-11-2013 10:16 PM
Another thought: Back in the day, aftermarket suppliers produced a fan-mount generator pulley specifically for the 40-48 generators with the screw-on pulleys. Probably a bit scarce, but I did see one of these on the auction site a while ago.
nospartsman 03-11-2013 10:48 PM
The most compatible generator with pulley fan mount and that functions with voltage regulator is the 1939 Ford Standard and 1939 pickup and truck.
G.M. 03-12-2013 08:03 AM
It's not just a matter of finding a pulley that fits but there are various sizes. You don't want one that it to large or it won't charge right. This is real important if you use an alternator. The ones with the pulley OD close to the threads for the screws are best. G.M.
big deuce 02-18-2025 12:16 PM
1 Attachment(s)
I know this is an old thread, but still relevant info. Here is a prime example of an aftermarket pulley I just picked up.
petehoovie 02-18-2025 12:22 PM
https://www.fordbarn.com/forum/attac...7&d=1739898800
