Old 01-31-2012, 09:33 AM   #1
V4F
V4F's Avatar
Default 5 speed conversion
i would like to change my ring & pinion . are they different on the 5 speed , open drive shaft , than stock ? ... thank you .. steve
V4f
V4F is offline   Reply With Quote
Old 01-31-2012, 09:37 AM   #2
denis4x4
denis4x4's Avatar
Default Re: 5 speed conversion
I'm running a stock 3:73 set of gears in my '29 CCPU with a 5-speed and open draft shaft
denis4x4 is offline   Reply With Quote
Old 01-31-2012, 11:25 AM   #3
Crazydaddyo
Crazydaddyo's Avatar
I'm running 5 speed with closed drive shaft (shortened stock torque tube) and a quick change rear end with a 3.48 final gear ratio. Cruises down the freeway @ 75-80 mph no problem. 2000 rpm @ 75 mph.
Crazydaddyo is offline   Reply With Quote
Old 01-31-2012, 12:12 PM   #4
V4F
V4F's Avatar
thanks . trying to be sure the stock ring & pinion will work .......... steve
V4f
Old 01-31-2012, 01:03 PM   #5
Charlie Stephens
Steve,
What is the ratio of your 5th gear?
Charlie Stephens
Old 01-31-2012, 01:05 PM   #6
callcoy
I think you should start by establishing your overdrive ratio, there are 265 versions of the "T-5" Borg Warner/Tremec transmission, from 16% to 67%. Your final drive ratio will no doubt be the result of the OD ratio, engine mods and vehicle weight. Crazydaddyo is an expert as he manufactures the slick T-5 the closed Ford driveline adaptor and has a on hand "learning curve" gathered from actual users.
Steve - Santa Rosa
callcoy is offline   Reply With Quote
Old 01-31-2012, 01:08 PM   #7
1931 flamingo
1931 flamingo's Avatar
I would think the ring gear would be model A, not sure what p/p cl/disc you have. Are you using stock model A starter?
Paul in CT
Old 01-31-2012, 07:55 PM   #8
jerry shook
I put a 5 speed in my 31, and left the stock ring gear in , it is to low of a gear for me. My t-5 must be a low gear trans. I am in 5th gear at 45 to 50 mph. I will be changing to a touring gear soon.
jerry shook is offline   Reply With Quote
Old 02-01-2012, 10:41 PM   #9
V4F
V4F's Avatar
need the clutch disc for the model a to t=5 conversion ...... thank you all
V4f
Old 02-01-2012, 10:42 PM   #10
V4F
V4F's Avatar
i need a s-10 clutch plate for the model a conversion .
V4f
Old 07-20-2014, 09:18 PM   #11
V4F
V4F's Avatar
************ HELP NEEDED .
i need a clutch disc for a model a to t-5 transmission . any help appreciated ...... steve
V4f
Old 07-20-2014, 10:15 PM   #12
Purdy Swoft
Purdy Swoft's Avatar
Paul in CT
Paul, I believe that Steve plans to use a later open drive rear end and is reffering to the ring gear in the backend.
Old 07-20-2014, 11:48 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
I think Steve needs a clutch disc.
Old 08-15-2014, 08:48 AM   #14
mollydog
Mike, Did you ever get the clutch disc you were looking for? I also need a clutch disc. Any help?
Mollydog
mollydog is offline   Reply With Quote
Old 08-16-2014, 01:15 AM   #15
Mike V. Florida
Mollydog
Not me, it was/is poor Steve he started this conversion 2 1/2 years ago.
Old 08-16-2014, 12:30 PM   #16
mollydog
Steve, I found Speedway Motors has the clutch disc. Mine is a 14 tooth spline. If that's what you need they have it for about $80.
Mollydog
Old 11-10-2014, 09:14 PM   #17
callcoy
Sorry I didn't see the posts for clutch discs earlier. Measure the clutch that you are going to use across the face, is it 9", 9 1/4", 10" and etc. Visit your auto parts store and ask for the listings for clutch discs for Chev. S-10 or GMC S-15's. See what sizes are available for all engines, STD. and optional, do any match up with your clutch plate dia.? If so ask if you have return rights and if so take one home to see if the springs in the disc will clear the flywheel bolts, if so you are home free. If not contact one of the fellows that sell the conversion kit and order one from them.
You have to remember that there are 265 versions of the Tremac/Borg Warner 5 speed, if you don't have a trans out of a S-10/S-15 you will have to figure out just what trans you have. There is a chart posted some where if you search S-10 t-5 trans conversion on here or the HAMB. There is a metal tag bolted to the tail housing that has a 4 digit number from memory it is maybe 1310 or 1350 then a dash and a 3 digit number that is the number you need to identify what car or truck it came out of, there are versions with 16% to I believe 67% over. I would offer to help but mine is in storage 2000 miles away.
Remember you will have to know what car or truck your trans came out of or match them up by placing the disc over you input shaft.
Steve - Santa Rosa
Old 11-11-2014, 04:51 AM   #18
brokenspoke
I'm running the same ^^^^
brokenspoke is offline   Reply With Quote
