Old 08-31-2011, 04:57 AM   #1
6deuce32yblock
Default cups
getting ready to assemble my 406 heads and in looking thru my head parts i found some cups. cant find any info in my shop book, so i thought i would ask the experts out there. using a comp cam with corresponding springs, so do i need to use these cups or discard. thanks
6deuce32yblock is offline   Reply With Quote
Old 08-31-2011, 08:39 AM   #2
Ford blue blood
Ford blue blood's Avatar
Default Re: cups
Those were used in Hi Performance solid lifter cam engines, 427 specificly, others I feel as well. Shims to establish correct spring heigth/tension were inserted under the cups. They were required when putting the 427 tripple springs on Boss 302 heads...so if your cam/lifters/springs are for a 406 Hi-Po then yes. Having said that be sure to check for spring bind at max lift.
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 08-31-2011, 07:01 PM   #3
Dave72dt
Default Re: cups
There were also some small cups used on some Ford engines that were placed on top of the valve stem. May not apply in your case.
Dave72dt is offline   Reply With Quote
Old 09-01-2011, 05:17 AM   #4
6deuce32yblock
Default Re: cups
thanks fellas. do you by any chance know what the installed spring height should be. seem to recall l.82 #.
Old 09-01-2011, 10:04 AM   #5
34pickup
34pickup's Avatar
Default Re: cups
Check out this forum:http://www.network54.com/Forum/74182/
That is where all of the Ford FE enthusiasts congregate.
34pickup is offline   Reply With Quote
