#18 | |
![]() Quote:
If you really have the flow of coolant through your radiator that is required and it’s still overheating. You have a radiator problem. Have you checked the timing? These are really simple cars. A good radiator is a must. That’s what dissipates the heat. You need the flow to get the heat to your radiator. A good radiator might actually allow your engine to run cooler than you might think it should. My last post. Good luck. |
