Old 07-24-2025, 04:47 PM   #1
randy c
Question how to keep windshield open
I have a1928 open cab pickup ,how do you keep windshield out for vent when driving. does it arms to hold it out?
Allen C
randy c is offline   Reply With Quote
Old 07-24-2025, 05:33 PM   #2
gdmn852
gdmn852's Avatar
Default Re: how to keep windshield open
Hello , I have a 31 roadster, and made up some wood dowels fitted between cowl rail and lower windshield frame, the wingnuts seem to loosen up with wind .
gdmn852 is offline   Reply With Quote
Old 07-24-2025, 05:49 PM   #3
Jim/GA
Jim/GA's Avatar
On open cars, remove the two stanchion wingnuts at the top of the windshield (only do one side at a time) and add 2 flat washers on there, then put the wingnuts back on snug when you have the windshield open to the position where you want it. Add the 2 washers to both sides. The windshield will stay there.
The stud bottoms out inside the wingnut before it is clamped tight to the stanchion.
I have seen people put wooden blocks, tennis balls, pool noodles, all kinds of stuff in the bottom of the windshield because they did not know about the washers.
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 07-24-2025, 06:15 PM   #4
randy c
thank every one for information, will try that to hot here in Texas to drive it like it is.
Old 07-24-2025, 09:15 PM   #5
FrankGModelA
Hi. I have the same problem with the same type/year vehicle. I see the answer below with adding washers. I’m near San Antonio and you’re right, it’s too hot to drive around with the windshield closed, even with the soft top off… ��
FrankGModelA is offline   Reply With Quote
Old 07-25-2025, 06:41 AM   #6
Big hammer
I bought the new fangled arms with notches in them, they hold the windshield open positively at any speed at any angle ! BTW the first notch or 1 1/2 inches open gives me the most air blowing down to my feet/legs .
get a bigger hammer tap done
Old 07-25-2025, 01:23 PM   #7
Jim/GA
Jim/GA's Avatar
Yea, that's probably a closed car, not an open car. The open cars only lock in at the top.
Jim Cannon
Old 07-25-2025, 08:34 PM   #8
mcgarrett
Thank you Jim C. for the tip to use washers behind the wing nuts. I wasn't having much luck keeping my Roadster windshield set where I wanted it. Your trick worked!
Old 07-25-2025, 09:10 PM   #9
ModelA29
ModelA29's Avatar
Try some rubber washers. You are looking to increase the friction to resit movement.
ModelA29 is offline   Reply With Quote
Old 08-06-2025, 06:24 PM   #10
David in San Antonio
David in San Antonio's Avatar
I tried the metal washers, and a combination of rubber washers and metal washers. It kept slipping so I progressively tightened down the wing nuts until one snapped off one wing. I replaced both with modern wing nuts and tightened them down more. The windshield worked its way closed anyway.
Late ‘30 Deluxe "Wretched Roadster"
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 08-06-2025, 06:34 PM   #11
stevests
stevests's Avatar
How damn fast you guys driving ???
stevests is offline   Reply With Quote
Old 08-06-2025, 06:51 PM   #12
SteveSTS- I appreciate the joke but just driving on regular roads at 20-30 mph the bumps are enough to close it up. I’m guessing the hardware is worn smooth. Maybe I’ll try roughing it up a bit. In the meantime, I fold over a small terry shop towel about four times and wedge it in on either side.
Alamo A’s Club
Old 08-10-2025, 12:29 PM   #13
stevemclark
stevemclark's Avatar
Here's an after market one that should work. .https://www.mikes-afordable.com/product/A45463C.html. . This too. https://www.mikes-afordable.com/product/A45477S.html. .New thumbscrews maybe. https://www.mikes-afordable.com/product/A45482.html.
It's not the destination ,it's the journey .
stevemclark is offline   Reply With Quote
Old 08-11-2025, 02:39 PM   #14
mcgarrett
Speed isn't causing the problem. I've experienced a combination of leverage acting on the windshield, vibration, and worn parts that don't fit right.
Old 08-11-2025, 03:28 PM   #15
Karl Wescott
Karl Wescott's Avatar
One consideration. There is "cone" that attaches to the windshield frame, and the post has a socket. The cone and post socket should have EXACTLY the same angle (the cone should be contacting the socket EVENLY and COMPLETELY. This makes a friction lock when modestly tightened (think Morse taper chuck and spindle on a drill press). Many reproduction parts (and restorations) have lost this critical detail.
If the studs are too long and bottom out in the wingnut, why not just trim them to a "correct" length? I do like to use a small washer between the nut and post to keep from galling the post. There are extra small od 3/8" washers made that have about the od of the wingnuts so look fairly unobtrusive.
Karl Wescott is offline   Reply With Quote
Old 08-12-2025, 01:10 AM   #16
Randy in ca
Randy in ca's Avatar
Along the same line as Karl stated above, the late expert Marco Tahtaras had this to add to a similar thread way back in 2010:
Randy in ca is offline   Reply With Quote
