Old 04-04-2022, 02:46 PM   #1
my4dv8
Default 32 cabriolet door windows
Hi , on our 32 cabriolet the previous owner said the door windows rattled when up. His fix was a “U” shaped piece of wood on the B pillar which requires the window to be down when opening or closing the door ,not ideal . Is there supposed to be rubber seals in the door top ? Or some sort of seal on the A or B pillar to steady the windows. Any pictures or input would be great.
my4dv8 is offline   Reply With Quote
Old 04-04-2022, 05:58 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 cabriolet door windows
Originally, the felt-covered rubber weather seals in chrome-plated or stainless steel channels on the A and B pillars were enough to prevent the window from rattling, assuming that there isn't excessive wear in the window run channels in the doors. (There was only a flap of the top material along the top of the window frame which did not contribute to rattle prevention.)
Old 04-04-2022, 06:42 PM   #3
my4dv8
Thanks David. Who would be a vendor for the felt-covered rubber weather seals in chrome-plated or stainless steel channels. Good point I will check the window runner channel felts in the doors also.
Old 04-04-2022, 08:51 PM   #4
DavidG
DavidG's Avatar
Bob Drake's catalog shows the stainless steel channels, but I did not see the rubber inserts or the felt covering tape therein. Carpenter used to carry the parts as well, but I found nothing in their current online catalog. Try thirdgenauto.com.
Old 04-04-2022, 09:38 PM   #5
petehoovie
petehoovie's Avatar
Old 04-05-2022, 02:54 AM   #6
deuce lover
deuce lover's Avatar
Off topic but please tell us about those '32 roadsters in the background.Orig NZ V8 or 4 cyl cars? Thanks
Old 04-05-2022, 04:11 AM   #7
Graham Freeman
Be careful when purchasing the channels/rubber from the above suppliers.
These channels are similar to 1933/34.
The reproduction channels are accurate but the rubbers supposedly for them when inserted are too narrow.
I tried from both suppliers when restoring my 34 cabriolet and found this out.
My problem was solved when I was able to purchase the correct width inserts from the Early Ford Store in CA.
These rubbers even have the correct felt like finish (although not very durable).
Graham Freeman is offline   Reply With Quote
Old 04-05-2022, 04:36 AM   #8
DavidG
DavidG's Avatar
Sheldon,
Not NZ, but rather USA. On the left is Mark Moriarity's V8 and on the right is the ex-Pat Fenner/ex-Par McFarland (RIP) Model B.
Old 04-05-2022, 05:46 AM   #9
deuce lover
Ah,okay.Thanks
Old 04-05-2022, 07:57 AM   #10
Pat/Ohio
Pat/Ohio's Avatar
Originally Posted by DavidG View Post
Sheldon,
David....I thought I recognized the Model B roadster in the background! I see Pat M's roadster is now located at the Early Ford V-8 Foundation Museum. Thanks for posting! Kinda tugs at the tear glands a little!
Stay Safe,
Pat
Pat/Ohio is offline   Reply With Quote
Old 04-05-2022, 09:15 AM   #11
VeryTangled
VeryTangled's Avatar
I see I'm late with this.
Those photos look like they were taken in Gettysburg. They look like Mark Moriarty's and Pat McFarland's (sp?). Mark's is a V8 and Pat's is a 4.
-Jeff H
Old 04-05-2022, 09:22 AM   #12
DavidG
DavidG's Avatar
Correct, the location was one of the Eastern National Meets held at Gettysburg, PA.
Old 04-05-2022, 09:24 AM   #13
DavidG
DavidG's Avatar
Pat,
I understand that Pat's other '32 roadster has a new home in Michigan along side my avatar, which is no longer mine.
Old 04-07-2022, 09:54 AM   #14
Planojc
Planojc's Avatar
I'm not sure where I purchased the stainless channels and rubber but the package for the rubber says that it came from Dale's Manufacturing Co. in Oklahoma City. It is called Convertible window rubber moulding #18-45983. 1932-39. Dale's may be wholesale only but they should be able to tell you where to buy it. Phone 405-631-8988
Planojc is offline   Reply With Quote
Old 04-07-2022, 04:10 PM   #15
BoxCar Tom
BoxCar Tom's Avatar
Is that Gene Hetland (RIP) with his back to the camera?
BoxCar Tom is offline   Reply With Quote
Old 04-07-2022, 04:25 PM   #16
DavidG
DavidG's Avatar
No, he was not in attendance at either of the Eastern National Meets held at Gettysburg.
Old 02-26-2023, 07:13 PM   #17
my4dv8
Scanned through third gen ,drake and carpenter but found none of the steel “U” channels to hold the window seals. Maybe my search was inadequate?
Old 02-26-2023, 09:33 PM   #18
DavidG
DavidG's Avatar
I checked last week and both the stainless steel channels and the rubber weatherstrips were in the Drake online catalog as well as fuzzy cloth tape covering. I searched with "convertible weatherstrips" and narrowed it down from there.
Old 02-26-2023, 10:23 PM   #19
my4dv8
Thanks David . Typical back order Bob ,it says unavailable , well the channel anyway. He did have the rubber. But using his SKU number lead me other sources.
Old 02-27-2023, 10:39 AM   #20
Terry,OH
Terry,OH's Avatar
The last time I bought the rubber from Drake it was already covered with the felt.
