Old 02-10-2022, 07:57 AM   #1
HS
Default Have a SKIP in Number 3 Cylinder when running
#3 Cylinder has a Skip when running. I changed plugs. Still have a Skip No water in The Oil, and No Oil in the water. Any suggestions on what might Be the skip when engine is running Thanks, HS
HS is offline   Reply With Quote
Old 02-10-2022, 08:33 AM   #2
Chuck Dempsey
Chuck Dempsey's Avatar
Default Re: Have a SKIP in Number 3 Cylinder when running
HS, are you POSITIVE you have spark to the plug? If you create a short gap between distributor wire and the plug, do you see sparks jumping between them as the engine runs? If not, I'd suspect your distributor.....
Good Luck.
Chuck Dempsey is offline   Reply With Quote
Old 02-10-2022, 10:18 AM   #3
Ayers1
Ayers1's Avatar
I would look at the distributor body first. Make sure you have continuity between the inside contact and the plug wire post on the outside of the body.
Ayers1 is offline   Reply With Quote
Old 02-10-2022, 10:36 AM   #4
rotorwrench
rotorwrench's Avatar
It may have a sticky valve on #3. Try running some Marvel Mystery Oil in the fuel. Nothing better to dissolve carbon or crud.
Old 02-10-2022, 11:43 AM   #5
HS
Hi Ayers! Thanks Do you know Wayne on Waynesboro If you do, Tell Wayne From Waynesboro Hugh Said Howry , I live in Clarksville VA Thanks Hugh
Old 02-10-2022, 11:45 AM   #6
HS
THanks to All I will try the Distributor Body
Thanks to all, Hugh
Old 02-10-2022, 12:35 PM   #7
eagle
eagle's Avatar
Lift the plug straps a quarter inch and watch the spark jump when its running. You'll be able to see if its erratic. Works best if its low light, easier to see.
Old 02-10-2022, 03:51 PM   #8
Ayers1
Ayers1's Avatar
Hi HS, I know a lot of guys by their cars, not necessarily by their name. If I run into him I'll tell him!
Old 02-10-2022, 05:53 PM   #9
ronn
thats what it sounds like to me....
