Old 07-30-2021, 06:40 AM   #1
mach0415
mach0415's Avatar
Default Stock Ride Height
Good day! I am wondering if anyone has a reference on stock ride heights for a 1928 Tudor, as well as measurement points? Thank you.
Thanks,
Mark in SC
"We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it.
mach0415 is offline   Reply With Quote
Old 07-30-2021, 05:04 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Stock Ride Height
Hi Mark,
Les Andrews' book "Model A Ford Mechanics Handbook Vol. I" says 18-11/16 +/- 1/2 inch to the CENTER of the front bumper to ground for a 1928 or 29 and 18-1/2 +/- 1/2 for a 1930 or 31. Measure with tires fully inflated to 35 psi. He does not give a similar measurement for the rear. Differences in tire size from different manufactures can change the heights.
Old 07-31-2021, 07:57 AM   #3
Tinbasher
Tinbasher's Avatar
Hi Mark: This is all that's out there for measurement. You should have a 1/2" between the bottom of the front Shackle and the Axle. I haven't been able to find a Riding height measurement on any of the frame charts that I've found. Being a body and frame guy this drives me crazy!! JP
Tinbasher is offline   Reply With Quote
Old 08-01-2021, 09:03 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Dyke's lists the ground clearance as 9 inches.
Bob Bidonde
Old 08-01-2021, 09:54 AM   #5
Tinbasher
Tinbasher's Avatar
There you go. Thanks Bob, It's been noted. I'll be working on my car tomorrow so I'll see what measurment this is. Axle clearance or height from the frame to the ground. JP
Old 08-01-2021, 10:05 AM   #6
Y-Blockhead
Y-Blockhead's Avatar
Where is that measured at?
Old 08-01-2021, 10:31 AM   #7
katy
katy's Avatar
The lowest point on the vehicle.
Old 08-01-2021, 10:32 AM   #8
duke36
Here you go. '28-29 scale Dwg. Interpolate as needed
Old 08-01-2021, 10:36 AM   #9
Y-Blockhead
I guess that would be the bottom of my tires then...
Old 08-01-2021, 10:41 AM   #10
Y-Blockhead
Good drawing Duke. Shows both front and back bumper heights. I have that same book. I notice the '30-31 are a bit lower in the rear.
