Old 03-09-2021, 02:17 AM   #1
Lawrie
Lawrie's Avatar
Default 99a main bearings
Can any one advise me a stockist who has the current manufacture main bearings for these engines,(39-47)2.499 std (King,Clevite or others)
Thanks Lawrie
Old 03-10-2021, 09:09 PM   #2
Lawrie
Lawrie's Avatar
Default Re: 99a main bearings
After a lot of hunting down , I ended up getting a set of clevite mains, as well as a set of King ones.
Lawrie
Old 03-10-2021, 10:16 PM   #3
Pete
If the scaresage gets too bad they can always be whittled out on a lathe.
Old 03-11-2021, 02:07 AM   #4
Lawrie
Lawrie's Avatar
Pete, I was going to look at fitting the 8ba centre and front mains but machine the small tag slot on the other side, and using the 81 rear main.
Lawrie
Old 03-11-2021, 08:21 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
I've used both Clevite as well as King bearings lately - both are high quality. I'm more concerned with bearing clearances than the brand . . . would not have a problem running most any of them.
Old 03-11-2021, 09:29 AM   #6
Yoyodyne
Yoyodyne's Avatar
Originally Posted by Pete View Post
If the scaresage gets too bad we they can always be whittled out on a lathe.
What material would you use? I need a custom set.
Yoyodyne is offline   Reply With Quote
Old 03-11-2021, 12:05 PM   #7
flatjack9
flatjack9's Avatar
8BA and 59AB front and center main bearings are interchangeable. The rear thrusts are different.
Old 03-11-2021, 03:53 PM   #8
Pete
Mild engine, bronze.
Race engine 75T aluminum.
Old 03-11-2021, 05:12 PM   #9
Mart
Mart's Avatar
Are the 99A and 59A different? I know the centre and front are the same 59A and 8BA. The rears are different 59A/8BA.
So are 99A and 59A different? I put a 99A together but just reused the old bearings.
Old 03-11-2021, 09:40 PM   #10
flatjack9
flatjack9's Avatar
99A would be 39 Merc and they had 2.499 main journals, so think they would be the same.
Old 03-11-2021, 09:43 PM   #11
Bored&Stroked
They are the same . . .
