The Ford Barn
-   -   99a main bearings (https://www.fordbarn.com/forum/showthread.php?t=295561)
Lawrie 03-09-2021 02:17 AM
99a main bearings
Can any one advise me a stockist who has the current manufacture main bearings for these engines,(39-47)2.499 std (King,Clevite or others)
Thanks Lawrie
Lawrie 03-10-2021 09:09 PM
Re: 99a main bearings
After a lot of hunting down , I ended up getting a set of clevite mains, as well as a set of King ones.
Lawrie
Pete 03-10-2021 10:16 PM
If the scaresage gets too bad they can always be whittled out on a lathe.
Lawrie 03-11-2021 02:07 AM
Pete, I was going to look at fitting the 8ba centre and front mains but machine the small tag slot on the other side, and using the 81 rear main.
Lawrie
Bored&Stroked 03-11-2021 08:21 AM
I've used both Clevite as well as King bearings lately - both are high quality. I'm more concerned with bearing clearances than the brand . . . would not have a problem running most any of them.
Yoyodyne 03-11-2021 09:29 AM
Originally Posted by Pete (Post 1994730)
If the scaresage gets too bad we they can always be whittled out on a lathe.
What material would you use? I need a custom set.
flatjack9 03-11-2021 12:05 PM
8BA and 59AB front and center main bearings are interchangeable. The rear thrusts are different.
Pete 03-11-2021 03:53 PM
Mild engine, bronze.
Race engine 75T aluminum.
Mart 03-11-2021 05:12 PM
Are the 99A and 59A different? I know the centre and front are the same 59A and 8BA. The rears are different 59A/8BA.
So are 99A and 59A different? I put a 99A together but just reused the old bearings.
flatjack9 03-11-2021 09:40 PM
99A would be 39 Merc and they had 2.499 main journals, so think they would be the same.
Bored&Stroked 03-11-2021 09:43 PM
They are the same . . .
