My local vendor stocks a set of stainless tubes for the hood hinges. For the same price I could buy solid stainless rod. Which is better?
An old trick back in the day was to stick a brazing rod in there. If would go with something solid for sure.
"The more things change, the more they stay the same." |
I use brazing rods.
stainless rod from the local hardware store.
But what was factory? I’ve seen both not sure what Henry used...
on the originals hood rods. the top way a tube and the sides were rods. I use stainless rod.
Here are some original hood rods. The top rod behind the radiator cap is a seamed 3/8" OD steel tube. The side rods are a solid 1/4" steel. The upper rod is difficult to remove without damaging. All these you see are beyond repair. Bent into a corkscrew or bent/crimped over at the ends. Whether you go with a solid or tubular upper rod, if something heavy comes down on your hood, it won't matter which you use.
A straight piece of 5/16" ID (3/8"OD) brake line is a pretty close fit for a top rod. But in the long run, a stainless rod won't ever rust. |
Think I'll go for rods, thanks for the input. Got wood dowel holding it together right now!
Where do you find a brazing rod that thick? ⅜" for the center rod I believe? Thanks.
I got them at a welding supply shop. That is very big to braze with.
I have always used stainless rods from the model A parts vendor .
#13 |
There are 3 places in a Model-A where this rolled tubing is used. Wanna take a guess where the other two places are>>
#14 |
Tie rod?
#15 |
#16 |
Tubes are stronger Learned this working on hydraulic rods and tubes ,more surface area to bend makes it stronger with less weight.
#17 |
Originally Posted by BRENT in 10-uh-C View Post
There are 3 places in a Model-A where this rolled tubing is used. Wanna take a guess where the other two places are>> Seamed gas lines and 28-29 radiator tubes. That makes about 5 seamed tubing applications. |
#18 |
Not sure if this counts As one but the rear radius rods Are seamed
#19 |
Lubricate your old rods in the hood. Then punch them out a bit. Connect a drill motor to them to spin them as you pull them out. Makes the process a lot easier.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#20 |
Thirty or 40 years ago my dearly departed uncle wisened me to that procedure. I must have passed it on to 100 people by now.
