The Ford Barn
-   -   Hood hinges - tube or rod? (https://www.fordbarn.com/forum/showthread.php?t=285419)
Jembow 08-11-2020 01:36 AM
My local vendor stocks a set of stainless tubes for the hood hinges. For the same price I could buy solid stainless rod. Which is better?
chrs1961815 08-11-2020 05:00 AM
Re: Hood hinges - tube or rod?
An old trick back in the day was to stick a brazing rod in there. If would go with something solid for sure.
Jacksonlll 08-11-2020 06:27 AM
I use brazing rods.
kenparker 08-11-2020 06:51 AM
stainless rod from the local hardware store.
dbaldwi3 08-11-2020 07:16 AM
But what was factory? I’ve seen both not sure what Henry used...
Big hammer 08-11-2020 08:29 AM
My late 31 Tudor has steel tubes, I've heard that wooden dowel could be used!
jw hash 08-11-2020 08:51 AM
on the originals hood rods. the top way a tube and the sides were rods. I use stainless rod.
Mike Peters 08-11-2020 08:57 AM
2 Attachment(s)
Here are some original hood rods. The top rod behind the radiator cap is a seamed 3/8" OD steel tube. The side rods are a solid 1/4" steel. The upper rod is difficult to remove without damaging. All these you see are beyond repair. Bent into a corkscrew or bent/crimped over at the ends. Whether you go with a solid or tubular upper rod, if something heavy comes down on your hood, it won't matter which you use.
A straight piece of 5/16" ID (3/8"OD) brake line is a pretty close fit for a top rod. But in the long run, a stainless rod won't ever rust.
Jembow 08-11-2020 08:59 AM
Think I'll go for rods, thanks for the input. Got wood dowel holding it together right now!
Ruth 08-11-2020 09:33 AM
Originally Posted by Jacksonlll (Post 1918952)
I use brazing rods.
Where do you find a brazing rod that thick? ⅜" for the center rod I believe? Thanks.
Jacksonlll 08-11-2020 10:52 AM
I got them at a welding supply shop. That is very big to braze with.
Purdy Swoft 08-11-2020 11:01 AM
I have always used stainless rods from the model A parts vendor .
BRENT in 10-uh-C 08-11-2020 11:12 AM
There are 3 places in a Model-A where this rolled tubing is used. Wanna take a guess where the other two places are>>
Ruth 08-11-2020 11:16 AM
Tie rod?
Gary Karr 08-11-2020 11:37 AM
Radiator support rods and horn rods
Truckerjim 08-11-2020 11:47 AM
Tubes are stronger Learned this working on hydraulic rods and tubes ,more surface area to bend makes it stronger with less weight.
Mike Peters 08-11-2020 01:03 PM
Seamed gas lines and 28-29 radiator tubes. That makes about 5 seamed tubing applications.
dbaldwi3 08-11-2020 07:30 PM
Not sure if this counts As one but the rear radius rods Are seamed
Chris Haynes 08-11-2020 08:04 PM
Lubricate your old rods in the hood. Then punch them out a bit. Connect a drill motor to them to spin them as you pull them out. Makes the process a lot easier.
McMimmcs 08-11-2020 08:25 PM
Thirty or 40 years ago my dearly departed uncle wisened me to that procedure. I must have passed it on to 100 people by now.
