Old 04-08-2014, 07:35 PM   #1
1 Raggedy Ride
Default '33-'34 Firewall body number plates info needed
The replacement "Body Number" Plate for the 1933-34 models, has the letters - LB- made in the center of the plate(tag)...Could someone please tell me what gets stamped to the left side of the "LB" , and to the right of the "LB" ???? The body style is 40-700 .....Thank You.....
1 RAGGEDY RIDE
1 Raggedy Ride is offline   Reply With Quote
Old 04-09-2014, 05:58 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: '33-'34 Firewall body number plates info needed
The model # to the left of LB and the sequence # assigned by the body builder when the body was built goes to the right. This is a 34 roadster body tag below.
Old 04-09-2014, 06:42 AM   #3
Terry,OH
Terry,OH's Avatar
The body of your car MAY not have been built by LB. In that case there is another tag.
Old 09-24-2019, 02:51 AM   #4
Graham Freeman
I have a LB repro body tag for my 34 cabriolet.
As an April manufactured (based on chassis number) Californian vehicle what would be an approximate number for the plate? 760LB xxxx?
Thanks
graham
Graham Freeman is offline   Reply With Quote
Old 09-24-2019, 07:44 AM   #5
DavidG
DavidG's Avatar
40-700 being a Tudor sedan suggests that it was highly likely Ford built and therefore originally would not have any body number tag.
Old 09-24-2019, 03:32 PM   #6
Graham Freeman
Hi David,
I am a little confused here where you refer to 40-700 being a Tudor sedan where as I was asking about a cabriolet 40-760?
Graham
Old 09-24-2019, 03:34 PM   #7
rockfla
rockfla's Avatar
Originally Posted by Graham Freeman View Post
Hi David,
Graham
Graham
Read the post that started "ALL" of this (from one raggedy ride)!!!!!
Old 09-24-2019, 04:12 PM   #8
Graham Freeman
I did read that initially, what I am looking for is an approximate number after the LB.
It should read 760 LB xxxx?
Old 09-24-2019, 07:26 PM   #9
DavidG
DavidG's Avatar
Graham,
Sorry for the confusion as I was addressing the question that started this thread, as Robert has pointed out. Next time perhaps you might consider starting a new thread when you have a new or different question.
P.S. Notwithstanding, you answered your own question.
