Old 05-03-2018, 08:16 AM   #1
29Cabriolet
29Cabriolet's Avatar
Default Sick Ahh-Ooh-Gah
The title should suggest where I am going with this post. My horn kind of sounds Ahh-Ooh-Gah, but is barely audible. When on the road and RPMs are up of course it's a bit louder but still quite weak. Would this seem to be a problem with the horn itself or more likely an electrical problem or deficiency? I am still 6V with stock generator, no voltage regulator or other "modernization" add-ons. Suggestions?
Thanks!
29Cabriolet is offline   Reply With Quote
Old 05-03-2018, 08:49 AM   #2
Standing Elk
Default Re: Sick Ahh-Ooh-Gah
The first thing I would do would be to take the back cover off the horn, clean everything up then lube it with a light oil or as I prefer, a teflon spray lubricant. Mine was acting the same way and after doing this it now works and sounds like new. Good luck
Standing Elk is offline   Reply With Quote
Old 05-03-2018, 09:19 AM   #3
cpf240
cpf240's Avatar
While you are in there doing what Standing Elk suggested, try grounding out the wire from the horn switch directly to a good ground point on the chassis. This might help determine if the problem is in the horn itself or in the horn button/wiring.
cpf240 is offline   Reply With Quote
Old 05-03-2018, 09:20 AM   #4
burner31
burner31's Avatar
http://modelabasics.com/horn.htm
Keith
Shawnee OK
'31 SW 160-B
Old 05-03-2018, 09:22 AM   #5
burner31
burner31's Avatar
some other ideas
File Type: pdf Model A Ford Horn Relay Instructions - A13820.pdf (40.0 KB, 53 views)
Keith
Shawnee OK
'31 SW 160-B
Old 05-03-2018, 09:42 AM   #6
BillEbob
BillEbob's Avatar
I'm not so sure about "grounding out" that wire! The retention screw fell out of my horn (pulling out wires) which, in turn, grounded out killing the engine (in traffic!) Engine wouldn't re-start, discovered fuse had blown when it grounded out!
Until this happened, I didn't know screw had fallen out. Luckily, back was not lost too.
Since that occurrence, I have been trying to adjust horn to sound correct again (with no luck as of yet.)
Bill
BillEbob is offline   Reply With Quote
Old 05-03-2018, 10:45 AM   #7
29Cabriolet
Thanks for all the suggestions guys! Now I have somewhere to start!
Old 05-03-2018, 11:13 AM   #8
cpf240
cpf240's Avatar
Bill
Just to be clear, I meant grounding out the wire that come from the horn button in the headlight switch assembly, as that is what the horn button is doing, providing a ground path. The other wire to the horn is hot at all times, and shorting it out could very well blow the fuse and/or kill the engine.
Old 05-03-2018, 01:27 PM   #9
Badpuppy
Check brushes for free travel. Springs get weak after 90 yrs. Sand armature contacts with fine grit & clean grooves with a toothpick. Horn relay usually solves weak horn button contact.
The yellow wire is the hot one, directly off the generator.
Old 05-03-2018, 04:48 PM   #10
Jacksonlll
Jacksonlll's Avatar
Try this. Get someone to push on the horn button while you back off the adjustment. Let the horn motor run up to speed for about a minute. It’s good for the motor to run. Then adjust it and it should sound better.
Old 05-03-2018, 04:56 PM   #11
aermotor
[QUOTE=Badpuppy;1624942]Check brushes for free travel. Springs get weak after 90 yrs. Sand armature contacts with fine grit & clean grooves with a toothpick. Horn relay usually solves weak horn button contact.
I found that brake cleaner will make the armature contacts look like new without sanding. Also cleans up the whole area. Let completely evaporate before hitting the horn button or use the non-flammable type.
John
aermotor is offline   Reply With Quote
Old 05-04-2018, 08:25 AM   #12
Badpuppy
Never heard of using brake cleaner for electrical contacts. Good to know, I"ll have to try it (after pulling the fuse). JacksonIII's idea is a good one too.
Old 05-04-2018, 05:24 PM   #13
Robert/Texas
Robert/Texas's Avatar
When the horns on my Model A’s get lethargic, all I do is to remove the covers and spray the brushes/armatures with non-flammable electric cleaner while the armatures are spinning. Then I lightly oil the bearings and put the covers back on. I need to do this about every three years or so.
Robert
Robert/Texas is offline   Reply With Quote
Old 05-04-2018, 08:27 PM   #14
chap52
chap52's Avatar
You Tube...Type in Model A horn"
Never had a resource like that when I was young. We would ask each other how to fix it and the guy that was the most convincing we listened to. Kinda like voting. Chap
Old 05-05-2018, 12:01 PM   #15
JBill
Or could just use electrical parts cleaner. I'm not sure what the difference is. Both are likely formulated to leave little to zero residue and evaporate quickly.
JBill is offline   Reply With Quote
Old 05-05-2018, 12:20 PM   #16
Bob Wright
Bob Wright's Avatar
Be careful using brake cleaner (it's also will ruing any paint that it comes in contact with). Try using electrical contact cleaner on the brushes & armature it's what it is designed for.
Bob
Bob Wright is offline   Reply With Quote
Old 05-05-2018, 12:53 PM   #17
Badpuppy
Talking Re: Sick Ahh-Ooh-Gah
Bob
WD-40 it is!
Old 05-05-2018, 04:18 PM   #18
cpf240
cpf240's Avatar
WD-40 it is!
WD-40 is NOT electrical contact cleaner....
Old 05-05-2018, 04:57 PM   #19
Lona
Lona's Avatar
I had the same problem with my horn and did most of the cleaning/adjustments mentioned. Ultimately found the generator was not charging enough so the horn got enough juice to go OOOO but not GAAAA. An adjustment of the third brush in the gennie solved the problem.
Glen
'31 Model A Deluxe Roadster
'35 Packard Convertible Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 05-05-2018, 05:57 PM   #20
Bob-A
Bob-A's Avatar
Cool Re: Sick Ahh-Ooh-Gah
It's amazing to me just how much juice it takes for the Model-A horn to work! I'm thinking it takes just as much if not more then the starter?!? But, what do I know, I also own a Chevrolet...
Bob-A
Bob-A is offline   Reply With Quote
