Old 11-06-2016, 04:58 AM   #1
harleytoprock
Default Re: F150 tranny with overdrive
Speedo won't need calibration with the F150 overdrive because the speedometer is driven off the drive shaft. A change in rear end ratio would require a calibration change.
harleytoprock is offline   Reply With Quote
Old 02-21-2017, 02:48 PM   #2
wensum
wensum's Avatar
It's interesting that because the gearbox has an electronic take-off for the speedo, I was told that an expensive solution was required.
However a Ford Falcon speedo cable fitted perfectly.
Also, with the 42% overdrive the speedo reads 75mph when the car is doing 62mph (100kph in NZ)
wensum is offline   Reply With Quote
Old 02-21-2017, 03:55 PM   #3
CarlG
CarlG's Avatar
Originally Posted by wensum View Post
It's interesting that because the gearbox has an electronic take-off for the speedo, I was told that an expensive solution was required...
You must have a different transmission than I have (which is a Tremec RTS), mine does not have an electronic take off for the speedometer.
... Also, with the 42% overdrive the speedo reads 75mph when the car is doing 62mph (100kph in NZ)
My transmission is 27% overdrive (4th gear). And since the speedometer take off is the original Model A gear, aft of the transmission, it has no bearing on what gear it is in as to how it reads.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
