Old 09-03-2016, 09:37 PM   #1
cwottinger
Default 1941 Pickup Drive Train
So i just purchased a 1941 Ford Pickup. The flathead motor appears to be locked up so I was thinking about putting a 327 small block in it. I realize i will have to adjust the firewall in order to do so. I plan to pair it with an automatic transmission and replace the original rear end or axel on the truck. I am curious if others have done something similar? I was wondering if anyone has replaced the rear axel with something more modern and what would possibly be a somewhat perfect fit in the truck? Any advice is much appriciated.
cwottinger is offline   Reply With Quote
Old 09-03-2016, 10:20 PM   #2
Charlie Stephens
Default Re: 1941 Pickup Drive Train
You will probably find that a few people here have done that but you would have much better response if you went to the HAMB website: http://www.jalopyjournal.com/forum/
Charlie Stephens
Old 09-04-2016, 08:47 AM   #3
Angledrive
Angledrive's Avatar
Yup, move over to the H.A.M.B.
Angledrive is offline   Reply With Quote
Old 09-04-2016, 09:38 AM   #4
41PICUP
41PICUP's Avatar
No, you don't have to move the firewall. Use the old way to mount the motor, that is use a saddle mount. Mounts just like a flat head, keep your stock running gear. Makes for a great 50's style hot rod.
41PICUP is offline   Reply With Quote
Old 09-04-2016, 02:18 PM   #5
hotrodA
hotrodA's Avatar
Since you want to change all the drivetrain, check out Chassis Engineering for top notch installation kits that work and fit. Pretty much the standard for a DIY changeover.
hotrodA is offline   Reply With Quote
Old 09-05-2016, 07:26 AM   #6
Cecil/WV
Cecil/WV's Avatar
Another piece of history destroyed.
Cecil/WV is offline   Reply With Quote
Old 09-05-2016, 09:46 AM   #7
hotrodA
hotrodA's Avatar
Maybe, but it's his truck.
Old 09-05-2016, 10:25 AM   #8
V12Bill
V12Bill's Avatar
They haven't built any since 1941 and there are no plans to build any in the future. When the last one is gone, they are all gone.
V12Bill is offline   Reply With Quote
Old 09-05-2016, 11:10 AM   #9
Brendan
Brendan's Avatar
yup, i bet he could get it to run in a day or so
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 09-05-2016, 01:46 PM   #10
hotrodA
hotrodA's Avatar
Where are my manners? Welcome to the Fordbarn! A place full of good information and diverse opinions and passions. Here's some: replace the "stuck" motor with a known runner. That's what I'm doing on my 41.
The expense and labor of a simple engine swap and radiator check versus a full blown drivetrain replacement has led to many a burn out, and an unfinished project for sale. That's what happened for me. I have ALL the pieces for the 350/350, 9 inch swap, but I guess my old age nostalgia longings won out. A flattie it is.
But, it's your truck. Time to do some parts math and check your abilities. Post a pic of the new member of the family.
Old 09-05-2016, 02:43 PM   #11
FHFD
FHFD's Avatar
Welcome.
Be sure and post some pics of your truck.
Build your truck your way for your optimum enjoyment, whatever that is.
"Get your facts first..then you can distort them as you please"
FHFD is offline   Reply With Quote
Old 09-05-2016, 05:52 PM   #12
jimvette59
jimvette59's Avatar
If it's a four cylinder DO IT. Just kidding.
jimvette59 is offline   Reply With Quote
