Old 02-13-2015, 12:03 PM   #1
marty in Ohio
marty in Ohio's Avatar
Default Spark plugs?
Mikes Affordable Parts sells a W 18 plug (part number A12405). Snyders sells a W 16 Y plug with the same part number. Both are Champion. Is Mikes plug hotter or better?
marty in Ohio is offline   Reply With Quote
Old 02-13-2015, 01:53 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Spark plugs?
You should be able to get whatever sparkler you like at your friendly local spark plug store. I prefer the extended tip plugs. I tend to like Autolite 3077.
Old 02-13-2015, 01:59 PM   #3
mshmodela
mshmodela's Avatar
I believe there is a thread that states W16Y plugs are a hotter plug and W18.... I own both types and and running W16Y as the Motorcraft TT10 but were too cold.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 02-13-2015, 02:05 PM   #4
goodoldvic
goodoldvic's Avatar
HOTTER DOWN TO COLDER - Spark Plugs
For those who may be interested, the following 7/8"-18 spark plugs will fit the Model A and were available as of a few years back. They are also not all the ones that I know of.
Champion (hotter down to colder):
W95D
W89D
W16Y
W20
W18
W14
W10
W85N
W80N
Also the original 3X and W18 which Champion lists as norm. Also according to Champion, the W16Y is hotter than the W18 at low speed but cooler at high speeds over 5500 RPM....(over 5500 RPM? ... maybe Speedy ED J, Pete, George Miller, Dennis Pierce would be interested... maybe even Brent)
Motorcraft (hotter down to colder):
TT15 (the same as Champion W89D)
TT10 (the same as Champion W14)
TT8 (the same as Champion W14)
TT4 (the same as Champion W10)
Autolite:
3076 (the same as Champion W14 and Motorcraft TT10)
Mopar (hotter down to colder):
P-9-7S
P-9-6S
P-9-5S
Prestolite (hotter down to colder)
78-10
78-8
Stitt (hotter down to colder)
137 BSP
197
147 B
13/10
Range is a key word when one speaks of heat range.
Reading these Champion numbers is not real difficult. For example, W20 or W18, etc.:
The W is the shell design and it always means 7/8-18.
I should also add that Champion has made changes over time. For example a C-16C, used in many a Model A, starts with a C, BUT it is a 7/8-18 plug. It was discontinued about 1979 and replaced by the W16Y. There are many like this.
The number is the heat range and the lower the cooler (unless other letters immediately follow, like Y for example, which depending on the letter or letters can change or affect the heat range):
1- 25 = Automotive and small engines
25 - 50 = Aviation
51 - 75 = High Performance
75 - 99 = Industrial and Special Applications
Larry B.
goodoldvic is offline   Reply With Quote
Old 02-13-2015, 04:36 PM   #5
Greg Jones
Greg Jones's Avatar
I know Larry B has posted this before and he certainly is not prone to making things up but my experience has been that the W16 actually runs colder than the W18. I also find that the W18 runs subtley different (hotter?) than the 3X. Now, those are just seat of the pants conclusions from driving and running the car so not terribly scientific. Larry is quoting Champion and I am guessing they know what they are doing. Just saying, with my setup (HC heads 5.5 and 6.0) that is my observation. YMMV
Greg Jones is offline   Reply With Quote
Old 02-13-2015, 09:36 PM   #6
edmondclinton
I was reading tonight on the Ahooga site where Mr. Brumfield posted basically the same info to one of his customers but he also had the following to say:
"Here is a list of a few 7/8"-18 plugs and the heat range according to the manufacturers. Also, according to Champion, the W16Y is hotter than the W18 or even a W20 at low speed but cooler at high speeds over 5500 RPM... which obviously will never apply to most Model Aers.
Moreover, most people report that the W16Y runs cooler than the W18 on a Model A at any speed. However, Champion's results would no doubt be determined under controlled conditions where the air/fuel ratio, spark intensity, etc., etc. would be near perfect which is not the case for most Model A's. So it's still best to use the following as a general guide but do your own tests and reach your own conclusions and opinions when running these plugs in a Model A."
edmondclinton is offline   Reply With Quote
Old 02-14-2015, 07:07 AM   #7
marty in Ohio
Wow!
Thanks guys. That's more info than I expected. Goodoldvic, it looks like you've done your homework. This gives me a lot to think about.
Marty
Old 03-18-2015, 01:57 PM   #8
Fred K-OR
Fred K-OR's Avatar
Another basic question about plugs from the guy that needs help.
Does it depend on the type of driving a person does? In other words if a person makes short drives (maybe less than 5 miles), should a person use a different plug that a person that goes 50 miles or more in a drive?
Thanks
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 03-18-2015, 02:01 PM   #9
mshmodela
mshmodela's Avatar
Thanks
I recall in Les Andrews' book that shorter trips need a hotter plug...
-Mike
Cleveland, Ohio
Old 03-18-2015, 02:34 PM   #10
Anteek29
Anteek29's Avatar
I've always been told that shorter trips need a hotter plug.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 03-18-2015, 02:35 PM   #11
C26Pinelake
Originally Posted by marty in Ohio View Post
Wow!
Marty
I suggest you buy at Autozone or TSC and save the shipping. Wayne
C26Pinelake is offline   Reply With Quote
Old 03-18-2015, 04:54 PM   #12
Fred K-OR
Fred K-OR's Avatar
Thanks guys. I need a new set so will get to it.
BTW is there an easy way to clean a plug other than using a wire brush on it? You can see I don't know what I am doing.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 03-18-2015, 05:03 PM   #13
CarlG
CarlG's Avatar
...BTW is there an easy way to clean a plug other than using a wire brush on it? ...
With one of these:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-18-2015, 05:05 PM   #14
Fred K-OR
Fred K-OR's Avatar
CarlG, looks like a great idea. What is the brand name or where does a person get it?
Come to think about it, I had one something like that years ago.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 03-18-2015, 05:15 PM   #15
CarlG
CarlG's Avatar
I got mine on eBay, that picture is from Harbor Freight. I've also seen them on Amazon.
Alaskan A's
Old 03-18-2015, 07:46 PM   #16
Quigley1930
Quigley1930's Avatar
I bought one from Harbor Freight and the hole for the plug was way to small. It came out as I was trying to insert the plug. Took it back and they returned my money.
Sewall Tyler
Quigley1930 is offline   Reply With Quote
Old 03-19-2015, 08:03 AM   #17
marty in Ohio
A friend of mine also found a plug sandblaster, but the hole was too small. We just put a couple slits in the rubber so that the big plugs fit in it. Works good.
Marty
Old 03-19-2015, 10:24 AM   #18
Quigley1930
Thanks Marty, I may get another and give it a try
Sewall
Old 03-19-2015, 10:41 AM   #19
Tom Wesenberg
Tom Wesenberg's Avatar
I use my regular blast cabinet to clean plugs.
Old 03-19-2015, 07:45 PM   #20
glenn in camino
glenn in camino's Avatar
I run restored Champion 3Xs.
