The Ford Barn
-   -   Spark plugs? (https://www.fordbarn.com/forum/showthread.php?t=161371)
marty in Ohio 02-13-2015 12:03 PM
Spark plugs?
Mikes Affordable Parts sells a W 18 plug (part number A12405). Snyders sells a W 16 Y plug with the same part number. Both are Champion. Is Mikes plug hotter or better?
Patrick L. 02-13-2015 01:53 PM
Re: Spark plugs?
You should be able to get whatever sparkler you like at your friendly local spark plug store. I prefer the extended tip plugs. I tend to like Autolite 3077.
mshmodela 02-13-2015 01:59 PM
Re: Spark plugs?
I believe there is a thread that states W16Y plugs are a hotter plug and W18.... I own both types and and running W16Y as the Motorcraft TT10 but were too cold.
goodoldvic 02-13-2015 02:05 PM
Re: Spark plugs?
https://www.fordbarn.com/forum/images/icons/icon1.gif HOTTER DOWN TO COLDER - Spark Plugs
For those who may be interested, the following 7/8"-18 spark plugs will fit the Model A and were available as of a few years back. They are also not all the ones that I know of.
Champion (hotter down to colder):
W95D
W89D
W16Y
W20
W18
W14
W10
W85N
W80N
Also the original 3X and W18 which Champion lists as norm. Also according to Champion, the W16Y is hotter than the W18 at low speed but cooler at high speeds over 5500 RPM....(over 5500 RPM? ... maybe Speedy ED J, Pete, George Miller, Dennis Pierce would be interested... maybe even Brent)
Motorcraft (hotter down to colder):
TT15 (the same as Champion W89D)
TT10 (the same as Champion W14)
TT8 (the same as Champion W14)
TT4 (the same as Champion W10)
Autolite:
3076 (the same as Champion W14 and Motorcraft TT10)
Mopar (hotter down to colder):
P-9-7S
P-9-6S
P-9-5S
Prestolite (hotter down to colder)
78-10
78-8
Stitt (hotter down to colder)
137 BSP
197
147 B
13/10
Range is a key word when one speaks of heat range.
Reading these Champion numbers is not real difficult. For example, W20 or W18, etc.:
The W is the shell design and it always means 7/8-18.
I should also add that Champion has made changes over time. For example a C-16C, used in many a Model A, starts with a C, BUT it is a 7/8-18 plug. It was discontinued about 1979 and replaced by the W16Y. There are many like this.
The number is the heat range and the lower the cooler (unless other letters immediately follow, like Y for example, which depending on the letter or letters can change or affect the heat range):
1- 25 = Automotive and small engines
25 - 50 = Aviation
51 - 75 = High Performance
75 - 99 = Industrial and Special Applications
Larry B.
https://www.fordbarn.com/forum/hamb/s...er_offline.gif https://www.fordbarn.com/forum/hamb/buttons/report.gif
Greg Jones 02-13-2015 04:36 PM
Re: Spark plugs?
I know Larry B has posted this before and he certainly is not prone to making things up but my experience has been that the W16 actually runs colder than the W18. I also find that the W18 runs subtley different (hotter?) than the 3X. Now, those are just seat of the pants conclusions from driving and running the car so not terribly scientific. Larry is quoting Champion and I am guessing they know what they are doing. Just saying, with my setup (HC heads 5.5 and 6.0) that is my observation. YMMV
edmondclinton 02-13-2015 09:36 PM
Re: Spark plugs?
I was reading tonight on the Ahooga site where Mr. Brumfield posted basically the same info to one of his customers but he also had the following to say:
"Here is a list of a few 7/8"-18 plugs and the heat range according to the manufacturers. Also, according to Champion, the W16Y is hotter than the W18 or even a W20 at low speed but cooler at high speeds over 5500 RPM... which obviously will never apply to most Model Aers.
Moreover, most people report that the W16Y runs cooler than the W18 on a Model A at any speed. However, Champion's results would no doubt be determined under controlled conditions where the air/fuel ratio, spark intensity, etc., etc. would be near perfect which is not the case for most Model A's. So it's still best to use the following as a general guide but do your own tests and reach your own conclusions and opinions when running these plugs in a Model A."
marty in Ohio 02-14-2015 07:07 AM
Re: Spark plugs?
Wow!
Thanks guys. That's more info than I expected. Goodoldvic, it looks like you've done your homework. This gives me a lot to think about.
Marty
Fred K-OR 03-18-2015 01:57 PM
Re: Spark plugs?
Another basic question about plugs from the guy that needs help.
Does it depend on the type of driving a person does? In other words if a person makes short drives (maybe less than 5 miles), should a person use a different plug that a person that goes 50 miles or more in a drive?
Thanks
mshmodela 03-18-2015 02:01 PM
Re: Spark plugs?
Thanks
I recall in Les Andrews' book that shorter trips need a hotter plug...
Anteek29 03-18-2015 02:34 PM
Re: Spark plugs?
I've always been told that shorter trips need a hotter plug.
C26Pinelake 03-18-2015 02:35 PM
Re: Spark plugs?
Originally Posted by marty in Ohio (Post 1033389)
Wow!
Marty
I suggest you buy at Autozone or TSC and save the shipping. Wayne
Fred K-OR 03-18-2015 04:54 PM
Re: Spark plugs?
Thanks guys. I need a new set so will get to it.
BTW is there an easy way to clean a plug other than using a wire brush on it? You can see I don't know what I am doing.
CarlG 03-18-2015 05:03 PM
Re: Spark plugs?
1 Attachment(s)
Originally Posted by Fred K-OR (Post 1052866)
...BTW is there an easy way to clean a plug other than using a wire brush on it? ...
With one of these:
Fred K-OR 03-18-2015 05:05 PM
Re: Spark plugs?
CarlG, looks like a great idea. What is the brand name or where does a person get it?
Come to think about it, I had one something like that years ago.
CarlG 03-18-2015 05:15 PM
Re: Spark plugs?
I got mine on eBay, that picture is from Harbor Freight. I've also seen them on Amazon.
Quigley1930 03-18-2015 07:46 PM
Re: Spark plugs?
I bought one from Harbor Freight and the hole for the plug was way to small. It came out as I was trying to insert the plug. Took it back and they returned my money.
Sewall Tyler
marty in Ohio 03-19-2015 08:03 AM
Re: Spark plugs?
A friend of mine also found a plug sandblaster, but the hole was too small. We just put a couple slits in the rubber so that the big plugs fit in it. Works good.
Marty
Quigley1930 03-19-2015 10:24 AM
Re: Spark plugs?
Thanks Marty, I may get another and give it a try:rolleyes:
Sewall
Tom Wesenberg 03-19-2015 10:41 AM
Re: Spark plugs?
I use my regular blast cabinet to clean plugs.
glenn in camino 03-19-2015 07:45 PM
Re: Spark plugs?
I run restored Champion 3Xs.
