Old 02-10-2015, 03:01 PM   #1
TDO
TDO's Avatar
Question speed odometer cable repair
The cable I'm referring to is the one that came in the kit I got when I change over to the T-5 overdrive. the cable is 10 feet long. Would be expense to replace. the end that goes to the transmission side is broke off. Does any one know some one who repairs these on maybe a home repair.
TDO is offline   Reply With Quote
Old 02-10-2015, 03:05 PM   #2
fordf1trucknut
Default Re: speed odometer cable repair
You can buy a new universal cable at parts store.
You just cut it to length and crimp the included end on.
http://m.advanceautoparts.com/mt/sho...edometer+cable
fordf1trucknut is offline   Reply With Quote
Old 02-10-2015, 03:11 PM   #3
29spcoupe
29spcoupe's Avatar
I had one come out in my spedo cable. I soldered it together with electric solder. Don't know if this is the accepted repair, but it has held for 10 months and the spedo works fine. John
29spcoupe is offline   Reply With Quote
Old 02-10-2015, 03:23 PM   #4
C26Pinelake
You might want to determine why the end broke off first and foremost, is there a kink ?
Wayne
C26Pinelake is offline   Reply With Quote
Old 02-10-2015, 07:57 PM   #5
SeaSlugs
SeaSlugs's Avatar
speaking of speedometer cables, what's the best way to clean the rust off one and how to repaint it? Or what would you guys do? Inner cable is fine and turns free but outer part is rusty but solid and flexible still.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-11-2015, 10:17 AM   #6
Mark in MT
A lot of times the cause of broken cables is that the speedometer head is turning too stiffly. They get tight over the years as the grease dries out and the pot metal parts swell. If you can't spin the cable with the tips of your fingers, the head needs service. About half of the speedometers that I get in are too tight on the drive.
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
