Old 12-03-2014, 09:22 PM   #1
Maclab58
Maclab58's Avatar
Default 28 AR starter switch
I have posted here about my struggles to get all the pieces to get my 1/2 shaft star teepee back in my E28 sport coupe after a bendix failure. I like all of the quirks of the AR model A's and the unusual starter switch is one. The copper triangular contact button on the starter is unique to those starters and is necessary to make the early switch work. After comparing a later starter case to E28 case I found that the early switch would work on a later starter. Guess what, no one makes the early 28 copper contact button. I ordered a standard field contact button and silver soldered a block of copper on top being careful to get properly aligned with the slot where the field coils solder in place. A machinist friend measured the dimensions of the E28 contact button and copied it for me. Now I just need to assemble and give it a whirl!
Maclab58 is offline   Reply With Quote
Old 12-03-2014, 10:02 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 28 AR starter switch
Nice work.
I use my WEN 250 soldering gun to solder the field coils.
Old 12-03-2014, 10:08 PM   #3
Maclab58
Maclab58's Avatar
I had him make me two of them. I'm going to build up a second starter as a spare.
Old 12-05-2014, 09:36 AM   #4
John Duden
John Duden's Avatar
I did this last year, I silver soldered the peice of brass on
John Duden is offline   Reply With Quote
Old 12-06-2014, 08:51 PM   #5
Maclab58
Maclab58's Avatar
Finished my E28 starter conversion. Worked great, 5/8 inch shaft starter with the E28 switch.
Old 12-06-2014, 11:35 PM   #6
Roadster62
Roadster62's Avatar
Is this starter going in a car with a multi disk clutch? If so how will the bendix spring clear? Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 12-07-2014, 06:57 AM   #7
Maclab58
Maclab58's Avatar
No it has a standard A clutch. It has been fun doing this, I needed to I try my hand at a starter rebuild any way. I think I will sell the original 1/2 inch shaft starter so someone doing a high points resto can use it. I spent a fair amount of time rounding up bendix parts for it, but oh well.
Old 12-07-2014, 02:33 PM   #8
Roadster62
Roadster62's Avatar
Does anyone make the bent starter foot rod for the early 28 starter? Bob
Old 12-07-2014, 05:13 PM   #9
Tom Wesenberg
I see them at times on ebay, but I think someone also makes a repro of it. I don't know who though.
