28 AR starter switch 1 Attachment(s)
I have posted here about my struggles to get all the pieces to get my 1/2 shaft star teepee back in my E28 sport coupe after a bendix failure. I like all of the quirks of the AR model A's and the unusual starter switch is one. The copper triangular contact button on the starter is unique to those starters and is necessary to make the early switch work. After comparing a later starter case to E28 case I found that the early switch would work on a later starter. Guess what, no one makes the early 28 copper contact button. I ordered a standard field contact button and silver soldered a block of copper on top being careful to get properly aligned with the slot where the field coils solder in place. A machinist friend measured the dimensions of the E28 contact button and copied it for me. Now I just need to assemble and give it a whirl!
Re: 28 AR starter switch Nice work.
I use my WEN 250 soldering gun to solder the field coils. |
Re: 28 AR starter switch I had him make me two of them. I'm going to build up a second starter as a spare.
Re: 28 AR starter switch I did this last year, I silver soldered the peice of brass on
Re: 28 AR starter switch 1 Attachment(s)
Finished my E28 starter conversion. Worked great, 5/8 inch shaft starter with the E28 switch.
Re: 28 AR starter switch Is this starter going in a car with a multi disk clutch? If so how will the bendix spring clear? Bob
Re: 28 AR starter switch No it has a standard A clutch. It has been fun doing this, I needed to I try my hand at a starter rebuild any way. I think I will sell the original 1/2 inch shaft starter so someone doing a high points resto can use it. I spent a fair amount of time rounding up bendix parts for it, but oh well.
Re: 28 AR starter switch Does anyone make the bent starter foot rod for the early 28 starter? Bob
Re: 28 AR starter switch Quote:
