Old 10-10-2014, 05:49 AM   #1
Racemo1
Default New bearing shim packs
Hello, I'm sure you all have been through this at one time?
Is there an easy way to peel shims off without messing up the whole pack?
Thanks a bunch...
Racemo1 is offline   Reply With Quote
Old 10-10-2014, 09:39 AM   #2
RonC
RonC's Avatar
Default Re: New bearing shim packs
Slightly heat them with a propane / map gas torch. They will fall apart. Don't overheat and melt them
RonC is offline   Reply With Quote
Old 10-10-2014, 11:07 AM   #3
J Franklin
J Franklin's Avatar
I use a razor blade, seems to work ok.
Old 10-11-2014, 10:15 PM   #4
Racemo1
Smile Re: Bent rear axle -'25 T Coupe
Looks like I may have a bent axle shaft. The rear wheel has a 5/8" wobble underway. I tried switching wheels from the other side and the runout persists. My question is. Has anyone ever straightened an axle without removing the rear end and changing it? Like removing the wheel and prying the end of the shaft while checking runout with a dial indicater. May not be Kosher but very curious.
Old 10-14-2014, 07:55 PM   #5
Racemo1
Looks like heat is the answer. Peeling one at a time!
Thanks...
