Old 09-05-2014, 12:13 PM   #1
19Fordy
19Fordy's Avatar
Default Truck Fan Pulley Questions.
1. Can anyone tell me what year Ford pick up this fan pulley is from?
2. How can I stop the oil from leaking out between the shaft and the hub?
The number on the shaft is 112036. the number on the hub is 112038. The pulley is wide belt and is 5 in. in diameter. Pulley shaft is 3/4 dia.Photos are below.
Old 09-05-2014, 12:14 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Truck Fan Pulley Questions.
More photos. The shaft is 3/4 in. Click on photos to enlarge.
Old 09-05-2014, 12:37 PM   #3
4tford
4tford's Avatar
You most likely have to much oil in the assembly. Remove the fitting and add oil til it starts to run out. Then rotate fan til the fitting faces down and drain out all the oil. When it stops dripping, install the fitting again.
4tford is offline   Reply With Quote
Old 09-05-2014, 01:02 PM   #4
Ross F-1
Ross F-1's Avatar
Looks like a '48 - '52 truck fan hub.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 09-05-2014, 01:21 PM   #5
Bruce Lancaster
And if you look at last picture in first group, you will see the mechanism, which is the tube protruding inward from the plug. You fillit with oil through that with hole upward, then rotate until hole points down and leave it that way for a while. Any oil above the level of the tube will run out and the remaining oil is the intended amount.
Old 09-05-2014, 02:42 PM   #6
Mac VP
Mac VP's Avatar
http://www.vanpeltsales.com/FH_web/f...ervicetips.htm
This explains it all including pics.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 09-05-2014, 08:24 PM   #7
Doug-F1
Doug-F1's Avatar
MAC VP, that is a good website
Thanks
Doug-F1 is offline   Reply With Quote
Old 09-05-2014, 08:46 PM   #8
zzlegend
zzlegend's Avatar
Thanks Mac. I learned some thing new. Mark.
zzlegend is offline   Reply With Quote
