Old 09-21-2013, 08:06 AM   #1
Tom Cavallaro
Tom Cavallaro's Avatar
Default Cowl Lights..
Is there a site or book specifically for installing cowl lights. I want to know what parts are needed and in what order they are to be installed. I was given the cowl lights and want to use them as turn signals. I could use the extra load to speed up the flasher...as I am using resistors for a load right now just to get the flasher working. Thanks in advance.
Tom
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong.
Tom Cavallaro is offline   Reply With Quote
Old 09-21-2013, 10:12 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Cowl Lights..
The service bulletins have several entrys about cowl lights(and some wiring routing in dome light heading too), and the Brattons catalouge has some pictures too
Old 09-21-2013, 10:21 AM   #3
CarlG
CarlG's Avatar
Les Andrews (#2) book has detailed instructions as well.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-21-2013, 12:34 PM   #4
Tom Cavallaro
Thank you Gentlemen.
Old 09-21-2013, 01:01 PM   #5
qtcoupe
qtcoupe's Avatar
a couple things you will need. snyder lists a cowl lamp marking tool # A13300-X and the wood spacers that go between the panel and the inside brace # A 13318. The hole position is critical because the light arm has a foot that fits over the cowl band. I drilled the final hole a little smaller and dremelled it to fit. I also put an oring on the shaft just in case it leaked when it rained or I washed the car.
qtcoupe is offline   Reply With Quote
