#61 | |
![]() Quote:
#62 |
Hello Everyone,
I have no horse in this race, I've never met Mr. Shewman, Mr. Haney, G.M., or Prof. Henry. G.M. and Prof. Henry I know from their postings here. I have had outstanding customer support from Mr. Haney on a coil issue that he made right when it was very likely not any of his fault, for this I give him huge props. Our car cools well, has never spit a drop of fluid (knock wood), and goes over mountains like the Larry Baily tour in Georgia's 2012 Eastern Meet, and can run down I-95 for over an hour at 65mph on a hot summer day, as it did at the end of the FordBarn Maine Tour last summer. One point to add about the high flow pumps. (Full disclosure, I have a set waiting to go on the car.) They seem to be recommended (and work 'best' with) with the 4lb pressure relief valve. [EDIT: I see the pressure valve is 3lb, not 4 as I previously stated.] -VT/JeffH Last edited by VeryTangled; 08-13-2013 at 04:59 PM. |
#63 | |
![]() Quote:
Just curious.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#64 |
OK friends, heres where I'm at. I drained down the system last evening and it was raining hard today so it was a good chance to take a look at what I percieved as "over heating". I pulled the left hose and there are no thermostats as someone already mentioned. I put back straight water and let the little girl idle for quite some time, took off the pressure cap and stuck a meat thermometer in the flow for a while and it never went higher than 182 degrees. the outside temp was around 65 or so. Maybe I am just an old worry wart ? I pulled the sending unit and cleaned it well and put a new tip on the wire. The dash gauge is up and down like a prostitutes underware, whats up with that ??
#65 |
Every problem I ever thought was the gauge always turned out to be a bad sending unit - usually the new repros. Got an NOS, put it in, and it's worked great ever since.
#66 |
I am not anxious to change what I'm running now because I don't have any issues at all, as I wrote earlier, I've never seen the car spit a drop on the ground and the fluid quantity doesn't change very much. I'm also conflicted about which way to go re: stats. It is my belief that our car doesn't have them installed right now. I just went and squeezed the hoses and can't figure where they would be, they don't seem to be in the upper hoses (our car is a '36, the engine has a tag on the bell housing that says 'Authorized Ford Reconditioner,' a stamped number, and Code 15, and I've never tracked it down as to the year of the block, but the pumps are in the heads). Another small complication is that I'm not actually sure what kind of temps our car runs at because the temp gauge doesn't have numbers on it and I haven't made it a priority to use the laser temperature reading gizmo regularly. Even in long downhill situations our gauge doesn't change more than about 1/4 inch or so, whatever that means temp wise. The hottest I've seen it, idling in a parking lot at the end of 65mph interstate run in the summer, and I could still see some air above the red liquid on the gauge. I am convinced that your test showed, on the downhill portion, that having the stats in your car absolutely kept the temps more in the desired operating range. We've been through almost every mechanical system on our car in the last four years, but we've stayed away from messing with the engine simply because it works so well. (Rebuilt or refurbished: generator, carb, dizzy, coil, plug wires, starter, steering box and horn rod, tranny, rear, springs, shocks, fuel tank, brakes and cross-shaft, muffler, and a new top, but that's not mechanical, just what I can think of right now.) I have a spare 21-stud that I just ran on a test-stand in June, and just can't convince myself that it would be better than what we're running now. So, status quo for me for the near future. -VT/JeffH Last edited by VeryTangled; 08-13-2013 at 05:22 PM. |
#67 | |
![]() Quote:
But, I'm with you. If it ain't broke don't fix it. I would never have given a thought about nor any effort whatsoever to thermostats if I hadn't had the overheating problem going over Rocky Mountain National Park last fall. Now, after all of my efforts, I'm convinced that my overheating problem was because one of my brass stats was only opening half way. I would probably have been fine even with those if they'd worked right. They had been fine for two years before that including to the top of Pike's Peak. We lives and we learns.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 08-14-2013 at 12:27 AM. |
#68 |
As some of you know Im having problems with my radiator, and after finding a radiator guy on the other end of Australia who is very knowledgable with early Fords [he has a number of them that are real gems] the question was posed about thermostats... Guess what, he doesn't run them. After questioning him further about it, seems our flatheads are not that critical with or with out. He said" If you have them in and its working well , Leave them in, if you have them out and working ok leave them out" Simple, Also any other "modern" car must run them, his words. SO there you go everyones right! For me I'll put them back in, thats just me..
"Came too close to dying to stop living now!" |
#69 |
Hello Everyone, I've commented many times about amazing the things I learn about these old cars. Also reading can be dangerous.
![]() Here's something that might add to the knowledge: -VT/JeffH Last edited by VeryTangled; 08-15-2013 at 08:10 AM. Reason: adding two more photos |
#70 | |
![]() Quote:
"Never complain,never explain"... Henry Ford II |
