Old 07-25-2013, 01:58 PM   #1
sidhartha
sidhartha's Avatar
Default Alternative brake light switch
Anybody know of a modern brake light switch that can be used on a 31 A? The repo's that I have doesn't seem to work.
sidhartha is offline   Reply With Quote
Old 07-25-2013, 02:06 PM   #2
spike
Default Re: Alternative brake light switch
try A & L parts ....he has one that works like the original..check the vendors section..good luck
spike is offline   Reply With Quote
Old 07-25-2013, 03:00 PM   #3
Bob C
I'll second A & L. They don't have a web site but their phone
number is 860-693-0112.
Bob
Old 07-25-2013, 04:36 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Remember those spring loaded, arm type switches used under the floorboards on old Chevys. The arm just goes above the brake pedal. Somebody? maybe Mac's, listed them in their hot rod section. Bill W.
(The existing wires should reach O.K. & it just screws to the bottom of the floorboard with 2 wood screws. The switch arm "might" have to be bent a little, but it bends easy, without breaking! I know a man that put one for his clutch pedal to operate a little buzzer, so he "knew" when he was ridin' the clutch!)
"THE ASSISTANT GURU OF STUFF"
Old 07-25-2013, 06:07 PM   #5
TerryH
TerryH's Avatar
The A & L one has a bronze bushing, so it does not stick or bind.........it works the best of any repro............
TerryH is offline   Reply With Quote
Old 07-25-2013, 06:47 PM   #6
Hugh in NC
Hugh in NC's Avatar
I bought a late model brake light switch like this from the local Carquest. Just make a little bracket and it goes in the same location as the original.
Hugh
Hugh in NC is offline   Reply With Quote
Old 07-25-2013, 07:57 PM   #7
Jerry in Shasta
Jerry in Shasta's Avatar
Go to a NAPA store and ask to see their catalog with brake light switches.
There are a whole lot of switches to check out.
JB
Jerry in Shasta is offline   Reply With Quote
Old 07-25-2013, 08:10 PM   #8
Duffy1
Do a search . A lot of info . I put a 29 switch on my 31 s/w . The 31 repro. I bought was junk . 31 switch caused me a lot of grief .
Duffy1 is offline   Reply With Quote
Old 07-25-2013, 09:06 PM   #9
Drive Shaft Dave
Catterpiller fork lift has A stop light switch that would work, in fact it Is the same switch that is used on a 49 to 54 chev. Maybe others.
Drive Shaft Dave is offline   Reply With Quote
Old 07-26-2013, 11:48 AM   #10
Willie Krash
Willie Krash's Avatar
Here's the PDF for A&L Parts,
http://www.scvcma.org/documents/bull...talog-2012.pdf
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
