Hello All
Have been trying to find a source for a mallory series 2301105 shaft bushing? Can anyone help me out? Thanks! |
It may be a part you'll have to have a machine shop make up for you. Not a big problem. Tinbasher
Try going to the EV8 board and do a search for "Bubba", he may be able to help you.
Paul in CT |
There is a bearing and seal store about 5 miles from me. Give them the ID, OD, and length and they might have it on hand. Cutter Sales 763-425-8696, Paul is the owner.
BTW, there are a few good hardware stores that still have trays of bushings. |
thanks gentlemen, some of you have a trove of information!
Here's a link to removing the oiler. Scroll down to #5 andwhile gripping the screwdriver handle give it a good clockwise twist and the oiler should pop out with no damage. If it's to tight to twist the screwdriver, then use the screwdriver in the same position as a lever, and lift a little to get the oiler moving.
https://www.fordbarn.com/forum/showth...tributor+oiler |
