Old 01-09-2013, 05:54 PM   #1
fredski
fredski's Avatar
Default repro cowl lights angle outward ??
cowl lights purchased from macs made by vintiqe . when i hold them in
place on car they are slightly outward enough to look off. phoned macs
they have no answer as to why. put my old original glass lens in place and
they look great other wise.
any ideas as to make these fit properly ? my originals fit straight,but are
to deteriated to use.
fredski
fredski is offline   Reply With Quote
Old 01-09-2013, 06:22 PM   #2
CarlG
CarlG's Avatar
Default Re: repro cowl lights angle outward ??
I had to make a shim/washer out of a PVC fitting in order for my repro units to fit straight.
Old 01-09-2013, 07:43 PM   #3
fredski
fredski's Avatar
seems like the only solution, i was thinking what you did would be
the only fix. any way now i know
i am not alone with same problem.
thank you for relply
fred
Old 01-09-2013, 07:55 PM   #4
James Rogers
James Rogers's Avatar
There are 3 screws under the bell that when loosened will allow for some adjustment. 30/31 models.
James Rogers is offline   Reply With Quote
Old 01-10-2013, 06:53 PM   #5
fredski
fredski's Avatar
did try but very little movement if any at all.
appreciate your reply
fred
Old 01-10-2013, 09:34 PM   #6
spike
James is right on the mark...loosen all three screws on the bottom put a little W-D40 on the plate and work it back and forth it should addjust to the right position. good luck
spike is offline   Reply With Quote
Old 01-11-2013, 10:14 AM   #7
fredski
fredski's Avatar
will try again, thanks
fred
Old 01-11-2013, 12:11 PM   #8
Richard Wilson
Richard Wilson's Avatar
On a set of reproduction 30-31 cowl lights that I recently installed the radius where the arm fits over the cowl band does not match the cowl band and this caused the lights to be angled outward slightly.
Richard Wilson is offline   Reply With Quote
Old 01-11-2013, 01:04 PM   #9
CarlG
CarlG's Avatar
That's why I shimmed mine out. I made a plastic (PVC) "washer" to fit between the cowl light arm and the cowl to space it out so that it would face forward. It has the added advantage of sealing for water leaks.
