Old 12-10-2012, 05:38 PM   #1
46woodie
Default dual carbs,aluminum heads for 46 flattie
OK experts,what's your opinion for putting on Offy heads and dual intake for dress.Not trying to build for Hi-Perf just nice running good looking flathead in a 46 Ford.Will I spend most of my time adjusting carbs vs driving?? Aluminum heads of stock compression ratio present any problems? Stock Ford carbs run fine? Thanks!!
46woodie is offline   Reply With Quote
Old 12-10-2012, 05:54 PM   #2
Barlea
Default Re: dual carbs,aluminum heads for 46 flattie
I'm no expert, but if you were to use a triple carb manifold and run only on the center carb it will look and run even better. Dual carbs is the reason the four-barrel needed to be invented. ..B.
Barlea is offline   Reply With Quote
Old 12-10-2012, 06:02 PM   #3
Vic Piano
Vic Piano's Avatar
I'm running that same basic set up on our '47 Convertible; it's been that way for almost 15 years with Offy deuce intake with two Holly 94's and Offy heads. If you synchronize the carbs, you should have no problems. I’m also running an electronic ignition on the ’47.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 12-10-2012, 08:07 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
The best thing you can do is a set of high compression heads and dual carbs setup right. It will look cool and have more poop. Walt
Old 12-10-2012, 08:25 PM   #5
Ol' Ron
Ol' Ron's Avatar
Now is the time to buy jWL's book. He spent allot of time and money ansering just that question.
Old 12-10-2012, 09:45 PM   #6
wga
wga's Avatar
For an alternate to the dual carb - the Navarro 4V intake + WCFB carb. No need to
synch.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 12-10-2012, 10:10 PM   #7
Henry/Kokomo
Henry/Kokomo's Avatar
Gotta agree with Ol' Ron. His book and JWL's book are required reading if you're going to make engine modifications. Even if nothing you read changes your mind, I think you'll be amazed at what actually works, why it works and what you get for the money you invest. That said, what you describe makes a good looking engine.
Henry/Kokomo is offline   Reply With Quote
Old 12-10-2012, 10:15 PM   #8
Rand
Rand's Avatar
Where do you get the said "books"?
Randy
Rand is offline   Reply With Quote
Old 12-11-2012, 11:23 AM   #9
El Rat
Sharp heads work well for me. In addition I use a two carb manifold. I like the look and I keep my generator (not alternator) in the standard location. As far as
synchronization I put on my trusty stock manifold and run each carb seperately. Then re-install the two carb manifold.
El Rat is offline   Reply With Quote
Old 12-11-2012, 02:36 PM   #10
dick lyons
dick lyons's Avatar
to EL RAT: what???
MNSHNR
dick lyons is offline   Reply With Quote
Old 12-11-2012, 03:18 PM   #11
ken ct
Contact Charlie,ny on here hes the guru on multiple setups. ken ct.
ken ct is offline   Reply With Quote
Old 12-11-2012, 06:55 PM   #12
phartman
phartman's Avatar
Randy
Yup, where can we order these books?
phartman is offline   Reply With Quote
Old 12-11-2012, 08:32 PM   #13
Fe26
You're two thirds of the way to the traditional Hop Up routine: Finned Heads, Dual Carb's and Extracted exhaust. This was the accepted way back in the day to get a few extra horses out of a stock Flattie. An additional bonus will be, if you set your dual carbs and ignition up just right you will gain an extra five percent in fuel efficiency.
Fe26 is offline   Reply With Quote
Old 12-11-2012, 08:47 PM   #14
JWL
Info for my book can be seen here:
http://www.flatheadv8.org/jwl.htm
Thanks for your interest.
JWL is offline   Reply With Quote
Old 12-11-2012, 09:07 PM   #15
46woodie
thanks guys ,you have all been very helpful.Book might be a great Christmas present to myself,what do ya think!
Old 12-12-2012, 01:46 AM   #16
Bassman/NZ
Bassman/NZ's Avatar
Essential reading!
Bassman/NZ is offline   Reply With Quote
