dual carbs,aluminum heads for 46 flattie OK experts,what's your opinion for putting on Offy heads and dual intake for dress.Not trying to build for Hi-Perf just nice running good looking flathead in a 46 Ford.Will I spend most of my time adjusting carbs vs driving?? Aluminum heads of stock compression ratio present any problems? Stock Ford carbs run fine? Thanks!!
Re: dual carbs,aluminum heads for 46 flattie I'm no expert, but if you were to use a triple carb manifold and run only on the center carb it will look and run even better. Dual carbs is the reason the four-barrel needed to be invented. ..B.
Re: dual carbs,aluminum heads for 46 flattie Quote:
Re: dual carbs,aluminum heads for 46 flattie The best thing you can do is a set of high compression heads and dual carbs setup right. It will look cool and have more poop. Walt
Re: dual carbs,aluminum heads for 46 flattie Now is the time to buy jWL's book. He spent allot of time and money ansering just that question.
Re: dual carbs,aluminum heads for 46 flattie For an alternate to the dual carb - the Navarro 4V intake + WCFB carb. No need to
synch. |
Re: dual carbs,aluminum heads for 46 flattie Gotta agree with Ol' Ron. His book and JWL's book are required reading if you're going to make engine modifications. Even if nothing you read changes your mind, I think you'll be amazed at what actually works, why it works and what you get for the money you invest. That said, what you describe makes a good looking engine.
Re: dual carbs,aluminum heads for 46 flattie Where do you get the said "books"?
Randy |
Re: dual carbs,aluminum heads for 46 flattie Sharp heads work well for me. In addition I use a two carb manifold. I like the look and I keep my generator (not alternator) in the standard location. As far as
synchronization I put on my trusty stock manifold and run each carb seperately. Then re-install the two carb manifold. |
Re: dual carbs,aluminum heads for 46 flattie to EL RAT: what???
Re: dual carbs,aluminum heads for 46 flattie Contact Charlie,ny on here hes the guru on multiple setups. ken ct.
Re: dual carbs,aluminum heads for 46 flattie You're two thirds of the way to the traditional Hop Up routine: Finned Heads, Dual Carb's and Extracted exhaust. This was the accepted way back in the day to get a few extra horses out of a stock Flattie. An additional bonus will be, if you set your dual carbs and ignition up just right you will gain an extra five percent in fuel efficiency.
Re: dual carbs,aluminum heads for 46 flattie |
Re: dual carbs,aluminum heads for 46 flattie thanks guys ,you have all been very helpful.Book might be a great Christmas present to myself,what do ya think!
Re: dual carbs,aluminum heads for 46 flattie Essential reading!
