#21 |
Here is someone's info on installing the F100 truck box., Its a pdf file, easy to save if you wish.
http://www.marinmodela.com/radiator/f100.pdf
Pete's Ponies Mustang RUSToration & Performance |
#22 |
#23 |
The kits that can be obtained from Miss Victoria or Mel Gross include all the modifications so that the original light switch/wiring is used. They are a complete bolt-in kit, no alterations to your car is necessary. And you can return it to original anytime with no scars (although I don't know why you would.)
