Old 04-11-2012, 12:23 PM   #1
mngreen
mngreen's Avatar
Default Valve lash clearance on Cragar OHV
Would anyone happen to know what the proper valve lash clearances should be (hot and cold) on a vintage Cragar OHV conversion on a Ford Model B block? I have contacted Steve Serr of the new Miller OHV repops but his pertains to his new aluminum head; mine is old skool iron.
Thanks,
Mike Green
mngreen is offline   Reply With Quote
Old 04-11-2012, 03:36 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Valve lash clearance on Cragar OHV
Mike, on my steel OHVs, I feel comfortable running .008" on intakes and .012" on the exhaust. I doubt you are going to run it hot enough to worry about heat dissipation on the exhaust valve, but if you think you may then add a couple thousandths more lash on the exhaust valves.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-11-2012, 03:45 PM   #3
mngreen
mngreen's Avatar
Measured cold or hot?
Charlie Yapp thinks I should try .012" intake, .015" exhaust, measured cold.
Old 04-11-2012, 05:36 PM   #4
BRENT in 10-uh-C
Well what do you think you gain, --or lose with .012/.015?
BRENT in 10-uh-C
Old 04-11-2012, 05:53 PM   #5
mngreen
mngreen's Avatar
Don't know--that's why I asked.
Old 04-11-2012, 06:28 PM   #6
BRENT in 10-uh-C
Well, with less intake lash, you get less valve lift. Granted it is marginal but with 1½:1 rocker arms, it does amount to something. This also affects the duration too. The biggest thing you are after is to make sure the valve has adequate time in the 'seated' position to dissipate its heat into the head to keep warpage at bay. Outside of that, excessive lash just wastes energy and creates a noise. Any idea whose camshaft you are using?
BRENT in 10-uh-C
Old 04-11-2012, 06:33 PM   #7
mngreen
mngreen's Avatar
No. I assume it is stock Model B.
Old 04-12-2012, 05:55 AM   #8
BRENT in 10-uh-C
Well, let me take a stab at this.... and compare it to the mechanical brake system of the Model-A. If a brake rod has wear in a clevis pin (i.e.: lash) we must depress the brake pedal a tad to tighten up the clearance before we see the brake shoes begin to move. The same applies with valve adjustment. If the peak lift of the cam lobe were .300", then with .000" lash the gross lift at the valve would be .450" (providing it has 1.5 rockers). If the the lash were set to 50 thousands clearance, then depending on the rocker arm configuration, you would only see (at max) .400" lift of the valve because the cam lifter must rise an addition .050" before the pushrod makes contact with the rocker arm and it can start pushing the valve open. I hope I have worded this to make sense.
BRENT in 10-uh-C
Old 04-12-2012, 07:56 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
The third word..........less is more.......no?
Old 04-12-2012, 08:58 AM   #10
BRENT in 10-uh-C
Ohh, now I understand where the confusion is. Yes, that should be 'more'. Thanks for pointing that out.
BRENT in 10-uh-C
Old 04-13-2012, 11:51 AM   #11
Jim Brierley
Valve clearance depends on the cam being used. Cragars and Denver Millers had 1.25:1 rocker arm ratios. Steve Serr's has 1.5:1. If using a stock B cam, multiply the B settings by 1.25 and set the valve lash at that. The original Cragars used 1928 style Buick rocker arms.
Jim Brierley is online now   Reply With Quote
Old 04-13-2012, 12:06 PM   #12
mngreen
mngreen's Avatar
Mr. Brierley:
Please pardon my ignorance, but I don't have the stock B setting either. Could you please provide the lash I should have on my Cragar using the stock B cam?
Just for a newbie, be kind:
COLD: .xxx" intake, .xxx" exhaust
HOT: .xxx: intake, .xxx" exhaust
Thanks,
Mike Green
Old 04-15-2012, 03:10 PM   #13
Jim Brierley
I didn't put in any numbers because it seems everybody and his second cousin sets them differently. I recommend .012" on the intakes and .014" on the exhausts for the B cam. On an OHV conversion you must be aware of the rocker arm ratio, and if it has many miles on it, the rocker arms can be worn and make it difficult to get an accurate reading. BTW, nice talking with you on the phone the other day!
Old 04-15-2012, 09:15 PM   #14
Art Bjornestad
Art Bjornestad's Avatar
I run 13 all the way around.....denver Miller and NO idea what cam I have. Yep,it's noisy.
Art Bjornestad is offline   Reply With Quote
Old 04-16-2012, 11:20 AM   #15
mngreen
mngreen's Avatar
So for the record, if anyone else out there needs to know, taking into account the 1.25 to 1 rocker arm ratio for a vintage Cragar OHV, lash clearance using a stock B camshaft are as follows:
COLD: .015" intake, .018" exhaust
NOW....after getting that bit of trivia cleared up.....back to reality! Turns out that my valves have beaten their way into the Cragar seats thus causing the valve stems to migrate into the rocker arm causing a cupping on the rocker to valve stem surface, so valid lash measurements go out the window!
Looks like a valve job is in order
Old 04-17-2012, 10:53 AM   #16
Jim Brierley
Take a compression test first, the valves may be OK. If compression is good, just remove the rocker arm assembly and have the rockers re-faced. This should be done on a valve machine with a radius put on them.
Old 04-17-2012, 11:07 AM   #17
mngreen
mngreen's Avatar
Compression at 100 to 102 psi on all four cylinders. After loosening the 3 valves I tightened previously (putting it back the way it was before I messed with it) the engine is running great, just a little knocking.
Old 04-17-2012, 11:36 AM   #18
MrTube
MrTube's Avatar
valve noise, at lease you know they are closing.
MrTube is offline   Reply With Quote
Old 12-03-2016, 02:08 PM   #19
V4F
V4F's Avatar
is 100# low ?
V4f
V4F is offline   Reply With Quote
Old 12-03-2016, 02:31 PM   #20
mngreen
mngreen's Avatar
Originally Posted by V4F View Post
is 100# low ?
Running great since I tried to mess with the rockers over 4 years ago!
