Old 12-08-2011, 02:56 PM   #1
My 34 Ford
My 34 Ford's Avatar
Default Head torque for 1934 221 engine
What is the proper head torque for a 1934 221 stud engine with aluminum heads?
My 34 Ford is offline   Reply With Quote
Old 12-08-2011, 03:39 PM   #2
fordscript
fordscript's Avatar
Default Re: Head torque for 1934 221 engine
The book says 35-40 ft/lbs
fordscript is offline   Reply With Quote
Old 12-08-2011, 04:01 PM   #3
Tinker
Tinker's Avatar
Torque. Run engine to get warm. Let cool and re-torque.
Old 12-08-2011, 07:02 PM   #4
Jack E/NJ
Jack E/NJ's Avatar
http://www.vanpeltsales.com/FH_web/f...rque-specs.htm
I go to 45 ft-lbs with cast iron & clean stud threads. Re-torque often till readings stabilize. I used to go to 30 with aluminum. Same re-torque method.
Jack E/NJ
Old 12-09-2011, 09:37 AM   #5
David J
David J's Avatar
Back in the dark ages I made the mistake { once } of doing them like a later model motor - 70 ft # & this accomplished thread removal on numerous studs . Pete at little dearborn when they were still on washington avenue in north MPLS got a real laugh out of that . He was a really great guy - despite the fact he enjoyed teasing a dumb 14 year old kid . YES I deserved it & in reality he was a HUGE help to me - God rest his soul . Roger is in charge now & he is a big help also . The troops have it right above & allz I will add is I use anti -seize on the nuts . David J
David J is offline   Reply With Quote
Old 12-09-2011, 10:59 AM   #6
Ol' Ron
Ol' Ron's Avatar
I've been using 45 ft/lbs on everything since the beginning of time. Broke and stripped too many . Now lets look at a blown nitro burning Hemi with 10 studs torqued to 100 lbs each, that means the head has a 1000 lbs of clamping force. NOW, lets take a Flathead with 24 studs torqued to 45 lbs equals = 1080 lbs. Kinda makes you think.
Old 12-09-2011, 11:05 AM   #7
Jack E/NJ
Jack E/NJ's Avatar
David J>>>I will add is I use anti -seize on the nuts>>>
Me too, David! But I think some will probably disagree.
Jack E/NJ
