Old 05-04-2026, 12:17 PM   #1
jeepguy1948
Default Head Gasket?
This question has undoubtedly been asked and answered many times; there are several different head gaskets available, which one should I use? And should I use sealant on it? This would be for an “B” motor with an “A” cylinder head. Thanks in advance
jeepguy1948 is offline   Reply With Quote
Old 05-04-2026, 12:41 PM   #2
Jim Brierley
Default Re: Head Gasket?
I recommend the BEST 509 copper gasket. They also make a fiber gasket, the thing I don't like about them is that when you have to remove it, you spend an hour scrapping the old one off. The 509 is an A gasket, do not use a B gasket as they may protrude into the combustion chamber.
Old 05-04-2026, 01:38 PM   #3
JayJay
I also use the Best 509, but I use the graphite version (509G) and coat with copper coat before installation. Yes, it’s a pain to remove, but that’s not a regular task.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 05-04-2026, 02:56 PM   #4
Gary WA
Gary WA's Avatar
Agree!! Copper Only! and i spray with copper spray(tacky not dry!)Model A Ford Garage ~ Brumfield Cylinder Head Gasket Instructionss
www.whidbeymodelaclub.com
Old 05-04-2026, 04:12 PM   #5
P.S.
509 copper gasket.
2024-2026 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 05-04-2026, 04:58 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
I'm with Jayjay, Best Gasket 509G.
Old 05-04-2026, 07:07 PM   #7
Synchro909
Synchro909's Avatar
A Model Aer on our recent rally blew a head gasket. Before retirement, he was a mechanic so replacing it was no problem.
I'd like to know what others think of his use of grease on the gasket before he tightened it down. He said he has done it that way for years.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 05-04-2026, 08:44 PM   #8
katy
katy's Avatar
Back in the 1950s working on Model As and V-8, that was the norm.
Old 05-05-2026, 12:58 AM   #9
Synchro909
Synchro909's Avatar
I have heard of it being done but I have always used high temp gasket sealer. I guess if it used to work, it will still work.
Old 05-05-2026, 06:39 AM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Things have changed somewhat in the way machining is done since then. Back in the days, many shops used a Rotary Broach that had something like 10 triangulated HSS cutters on a wheel. Often the cutters were slightly out of height alignment, and the speeds were not always optimal, so the RA finish was more akin to looking at a Bastard File rather than a smooth surface. Copper gaskets then were also softer, so the wax-based greases assisted in allowing the gasket to move & settle when the head nuts were being torqued. Today, most automotive machine shops are using a CBN cutter with a variable speed head that allows the surface RA to be really smooth, -hence no real reason to use the modern greases.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-05-2026, 08:58 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
I suggest you use any of the Best brand head gaskets.
Bob Bidonde
Old 05-05-2026, 09:09 AM   #12
BRENT in 10-uh-C
The one question that has not been discussed above is has this 'B' Block been modified for using an A head on it?
BRENT in 10-uh-C
Old 05-05-2026, 09:28 AM   #13
katy
katy's Avatar
We always used the copper clad gaskets, not the steel ones.
Later years some people used a thin coat of spray aluminum paint and let it dry before installing.
Old 05-05-2026, 11:31 AM   #14
Jim Brierley
I spray with aluminum paint because it acts like glue, copper coat never dries, so remains slippery. light coat first, let dry, then a heavier coat and install when still tacky.
Old 05-05-2026, 11:49 AM   #15
ursus
Would the aluminum spray paint work on a graphite type head gasket like the 509-G?
